Hi,
I have an HD camera feeding into a component video distribution amp (3:1) one of the outputs is going into the component input of a HD plasma monitor (this works) the other output needs to go to a coax signal. From the green output of the component I have a RCA adapter to BNC connector coax cable going to a composite in to a video monitor. My composite signal is extremely snowy. Any ideas? Thanks
Off-hand, I'd say it was a bad cable. How old is that BNC coax? But also, I'm confused as to whether you're taking an HD signal to a standard-def monitor. Also, there are issues about what's coming out of that "green output." (I'm assuming your are talking about your "Y" signal.) Wouldn't you get monochrome? You've got a lot of unknowns here for me to fully assess.
In short, I kind of think you're trying to do something that really shouldn't be done. It seems you would need an intermediate component-to-composite adapter between distribution amp and monitor. -
The green is the "Y" signal. It's a component out of an HD camera. I'm not even getting a clear monochrome signal. I will try a new coax cable. I'm thinking that I will need a component to composite adapter. Thanks for for help.
EZcap USB (composite) VS Blackmagic VIDEO RECORDER (component)
By wagz82 in forum MacReplies: 5Last Post: 15th Sep 2010, 20:14 -
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 21:48 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 22:46 -
Component vs composite cables
By PhoneMatt in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2008, 07:36 -
Trying to hook up Component to Composite video
By Airliban in forum Media Center PC / MediaCentersReplies: 8Last Post: 28th May 2008, 21:04
