I am using Videopack 4.0 and i wanna make a VCD witha menu conformed of one still bmp image and some audio playing encoded in .mpa format. I have only one mpeg track but i want to have chapters on it like dvd and i want them to be able to be selected through the remote control. In the still image in the menu i'll include numbers from 1-10 with the song titles(it is a concert) so you press the number on the remote and you can go to that specific chapter. I don't know if it is possible in that way, but what i am saying is that i don't want to split the mpeg into a lot of parts so i only have one playlist. My problem is, how do i link the entry points with the remote or something like that. Oh, another thing, when i burn the disc and play it on my standalone DVD player, the menu displays ok but the music sounds a little bit corrupts and in my pc it sounds fine. Also, how do i return the clip after it is finished to the menu?? And is there a way to do it, that when you load the disc the menu loads automatically????
www.ciaw.cjb.net
Kantele Industries Co. -
I tried to make a menu with audio but the audio was crappy. So i gave up.
To make chapters you have to make a playlist node for each chapter then select "play item" then select "properties" and enter the entry point for this chapter. Repeat this for every chapter. In the menu you have to edit the buttons. Just creat a button for each chapter and put a name. Link each menuitem to a chapter.Click the riht mouse button select "Desktop" and disable "Show menu routings". This way you can link the "next", "previous" and "return" buttons. -
Ah, i forgot. Search the forum for "VideoPack" , "Menu" and "Chapter" for more info.
