12
Results 1 to 10 of 10
Last edited by Anonymous4; 11th Mar 2017 at 11:50. Reason: Scrubbing myself from the Internet.
I remember a huge thread on the ADVC 100 because I was considering it at the time...something about holding a button down for 10 seconds or somesuch to defeat MV
Not all of the ADVC-100's could defeat macrovision. I think when I purchased mine it was a newer version of the ADVC-100 so the macrovision couldn't be defeated.Originally Posted by zoobie
12
Last edited by Anonymous4; 11th Mar 2017 at 11:49. Reason: Scrubbing myself from the Internet.
12
12
Last edited by Anonymous4; 11th Mar 2017 at 11:47. Reason: Scrubbing myself from the Internet.
ADVC settings for Canada
NTSC
7.5 IRE
Locked Audio
As for audio, it is uncompressed PCM at nominal levels. If the audio is low, that means input audio is low. Fix the source.
DIP switch settings allow 16bit/48KHz Stereo or 12bit/32KHz (intended for 4 channel) Normally, use the former.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
At a stretch, you may have an impedance mismatch between your source and the Canopus. How do other audio sources compare?
John Miller
Macrovision and Canopus ADVC 110
By nikgelfi in forum Capturing and VCRReplies: 2Last Post: 13th Apr 2011, 17:09 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Canopus ADVC 110 Possible problem?
By Drexter in forum Capturing and VCRReplies: 4Last Post: 20th Feb 2010, 22:10 -
JVC HM-DH30000U + ADVC-110 or ADVC-300
By cadguy4u in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2009, 14:29 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 16:15
