can we crop a wmv file with virutaldub mod? if not with what soft can we do that? i want to cut some portions on top and bottom of the video where i see some texts( advertisements). it is not on the video. so i think with croping i can avoid the ads.
i would like to ask the learned people what is the difference between virtual dub and virtual dub mod? thanks
Use virtualdub with the wmv plugin, http://home.comcast.net/~fcchandler/Plugins/WMV/index.html
Crop under Video->Filters and add the null transform filter and then click on cropping button. -
You could crop most WMV formats with the newest VD versions if you add the WMV plugin, but you would have to output in a different AVI type format. With VirtualDub Mod, you would need to use a AVISynth script to open newer WMV formats. VD Mod is an older modification of VD 1.5 that can open MPEG and a few other video formats, but it still outputs a AVI type file.
If your final output is going to be WMV, you could output as DV-AVI in VirtualDub, and put that back into Windows Movie Maker and convert back to a WMV format. But there will be some quality losses in the conversions. Probably better ways to do that, but I rarely use WMV. -
In VirtualDubMod try the DirectShowSource() template at the bottom of the Open Video File dialog. AviSynth must be installed.
WMV to Avi(xvid,mp3) using VirtualDub - huge destination file
By chm in forum Newbie / General discussionsReplies: 9Last Post: 20th May 2010, 17:29 -
How to Crop WMV Files ?
By devilcoelhodog in forum EditingReplies: 3Last Post: 23rd Mar 2010, 00:08 -
Can I crop in certain sections of video in Virtual Dub Mod
By blackskimask in forum EditingReplies: 15Last Post: 5th Aug 2009, 06:22 -
vob to wmv crop/aspect ratio???
By eao1 in forum Newbie / General discussionsReplies: 6Last Post: 29th Mar 2009, 14:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
