Hi,
I have an avi file on my computer that plays perfectly however, when I try to burn it to DVD it is always out of sync by several seconds no matter what program I use.
I have tried using DVD Flick, Avi2DVD and also created an mpg using VirtualDub and TMPEGnc but nothing seems to have worked so far.
I've made a number of DVD's using these methods and have never encountered this problem before.
I'd be grateful for any advice or assistance anyone can offer.
Thanks guys.
Results 1 to 9 of 9
Originally Posted by jimlahey
or it is a constant desync ?
The first type you can try to change audio tempo to play audio faster or slower, or reclock it
The second type, check if it has delays, in this case you can use tools like AVIMux-Gui that will fix your movie file
hope this helps -
It's a constant desync from what I can tell but it is in sync as an avi file.
So, find out the amount it's out of synch and fix it. Perhaps there's a delay in the AVI you're not taking into account when making the DVD.
Sorry to be a pain but how do I do that? I'm pretty much a novice when it comes to this kind of stuff.
The avi doesn't appear to be out of sync at all when I've watched it. -
Try save the audio as wav. Use for example avidemux, open the avi, under video choose copy, under audio choose wav pcm and save as a new avi. Check the sync and if it's okey convert it to dvd. Or you could try convert directly to dvd mpeg in avidemux also.
If that wont help then post the details from the avi, what video and audio codec, bitrate, etc. Use MediaInfo. -
add the movie
Generate data from source ( or something like that )
SAVE
it will make a new AVI file without delays, or some other problems -
I'll give that a go, thanks guys.
I'll let you know how I get on with it. -
Yes! AVIMUX-GUI worked!
Thank you so much guys, this site really is the best!
Cheers.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05
