Hi all,
I am trying to copy a VHS tape to DVD.
I use a Panasonic AG-7350 (repaired by myself) as source and a Dazzle DVC-170 as input to the computer.
Now the question: the tape I am working on has two audio tracks:
- one stereo track was recorded "camera audio" : the original speaks and so on
- one stereo track has the "mixed" audio : music and so on - the audio you hear when you use the tape in a "normal" vcr
I would like to acquire in DVD the video and both audio tracks, creating a DVD with the option of choosing the audio track to hear.
I am new in this sector of technology, but my impression is that I have to acquire video and all the audio tracks at once, without taking two passes (one pass: video and original audio, second pass: mixed audio) - because it would be rather difficult to "sync" all the tracks with two passes.
I think I could connect two audio channels to the two Dazzle audio inputs and the other two audio channels to the PC audio board input channels (can use a very good PCI audio board for this).
I looked at Avid Liquid 7, but I cannot find a way to acquire video and 4 audio channels at once.
Maybe two passes with some sort of external sync...
Is there anybody who can give me some suggestions, please ?
Thanks !
Regards
It would be extremely easy to sync up, and it would be impossible to capture them together anyway. Easy for me, that is. It's mostly a matter of setting the first frame in an editor, and a last frame, and then cropping both videos to the same identical length. Then demux both, take the video from one, take both audio, and author in software that supported multi audio (TDA v3 is my suggestion).
Many thanks, lordsmurf.
Will surely try as you suggested... looks simple.
Just for curiosity... how much are the speed fluctuations of a pro VCR ?
In other words... Given two runs of the same tape (say 1 nominal hour), how many seconds in time can they differ from each other ?
Thanks again,
regards -
They won't differ. At most, the interlacing may be slightly out of step, but it'll only be 1 frame, so 1/25th of a second, nothing easy to notice at a splice mark, or even as an audio drift (if any).
an idea for TRUE video restoration
By unclescoob in forum RestorationReplies: 36Last Post: 5th Apr 2012, 08:57 -
Best Video Restoration
By DrWahoo in forum RestorationReplies: 2Last Post: 29th Mar 2012, 00:53 -
Best lcd monitor for video restoration
By buckethead in forum RestorationReplies: 42Last Post: 14th Apr 2011, 09:36 -
Filter suggestion for old video restoration
By the_provider in forum RestorationReplies: 11Last Post: 27th Apr 2010, 18:02 -
Nero’s DVD-Video/Multichannel Plug-in
By DragonKnight in forum Authoring (DVD)Replies: 11Last Post: 8th Oct 2007, 18:43
