Hey I am trying to edit a bunch of xvid .avi files using divx author and then exporting them as an .avi however, divx author only lets you export them as .divx video files. Can anyone help? Or suggest another editing program that may work better?
Just rename them .AVI. If you aren't using things like menus and chapters .DIVX is the same container as .AVI. Even if you are using those features any decent player should be able to play the files -- it will just ignore the extra stuff.
cool thanks that worked, but what about Subtitles? my subtitles aren't getting hardcoded into the exported file..
I don't think Divx Author hard codes subtitles. It includes them as a separate data stream within the file. The player overlays the subtitles while playing the video. That is one of the extended features of .DIVX and Divx Ultra players. You can leave your subtitles as separate files and use a player that automatically locates and displays them.
i don't think that's going to work for me because i plan on streaming the exported .avi on my xbox 360. You know of any other programs that hardcode the subtitles?
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 19:16 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 20:28 -
Cropping in Divx Convertor or Divx Author???
By rahul.never2far in forum EditingReplies: 9Last Post: 25th Sep 2007, 11:28
