Have not been here in awhile but I could use some advise.
I had to reinstall my software on my computer. In the past the MyDVD Studio Deluxe version 6 by Sonic has worked. Now I must be missing an upgrade or patch because I get error messages and sometimes the VHS capture will not burn to the DVD. I am fed up with Help from Roxie who now you have to go to for help.
I have read many complaints about Roxie’s new software that I was considering to replace my older software.
I have Windows XP and ample harddive capacity. Software I have besides the MyDVD mentioned above is as follows;
Windows Movie Maker
Adobe Creative Suite Premium CS2 that has various programs. I do not use most of them or as yet learned many of them.
Nero DVD burning software
Canopus capture card; do not recall the model number.
Can any of the above be used without purchasing another VHS to DVD software. I really liked the MyDVD because it was easy to use but the time to capture and burn is not desirable. Now the error messages and not burning at times is getting on my nerves.
I have not tried any other software I currently have and do not know if additional software will be required. I am converting my VHS movies to DVD and have done many but it is slow and I have many more VHS movies to do.
Can anyone advise me on what I need or software that will work better than MyDVD besides Roxie’s products?
If there is an upgrade or patch I need for MyDVD Studio Deluxe V6 please tell me where I can find it. Roxie’s site and patches do not help.
Thanks for your help and advise.
Thanks for the reply. I will have to get back with you after checking your suggestion out in a few days.
Can a newer verson of FFMPEG be used with SVCD2DVD
By RJRobb in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 18th Jan 2014, 07:15 -
how do I REMOVE the v-chip from newer televisions
By lostinlodos in forum DVB / IPTVReplies: 42Last Post: 26th Jul 2011, 00:17 -
Explain the format for newer HD camcorders
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 22:45 -
Update to a newer version
By awhirr in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 25th Oct 2010, 14:19 -
Newer Binaries?
By theorik in forum ffmpegX general discussionReplies: 0Last Post: 30th Sep 2008, 02:39
