If possible are you able to have 1 audio track play whilst you navigate through different sections of the DVD?
So as you scroll through the differnt menu pages the song doesnt restart everytime you change page?
Im not looking for the song to pick up where it left off after a video has been played, just whilst you are navigating around.
Also I would like to have for e.g. 3 different options and each one has a black and white photo as the button but as you navigate over it I would like it to change to colour.
I normally get just a highlight bar using Sony DVD architect but if the images link to the colour version each time the cursor moves over them instead that would be cool.
I can use Adobe Encore if I have to, but am more comfortable in DVD architect.....but whatever gets my results!
Thanks.
	You cannot have audio run through a menu change in a DVD. The spec simply does not allow it.
 What you could try is putting a gray, semi-transparent overlay (highlight) over the button when it isn't selected, and have it go completely invisible when it is selected.Read my blog here.
	Ok thanks, the audio is out.
 gunslinger, is what you are describing able to be done in DVD architect or encore? What do you use?
 I will attempt it when I get home.
	I use DVD Lab pro, but it should be doable in any good authoring app that allows you control over the overlay colour and opacity. Read my blog here.
  trouble with SVCD2DVD menu selection highlightingBy bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Sep 2011, 15:59
  Extract video from 2 home DVDs - combine to single DVD with menusBy gutted in forum Newbie / General discussionsReplies: 5Last Post: 24th Apr 2011, 15:31
  Automatic Title and Audio Selection?By kwanbis in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 4th Aug 2010, 02:41
  Highlighting a specific part of a Video..? How?By Moontrash in forum EditingReplies: 6Last Post: 14th Oct 2007, 08:04
  Avid Lquid 7 menus..play chapter and play allBy cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 02:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
