Hello All - I have a problem with the sound of my film when it is burned to a DVD.
When the file is rendered/exported and the clip is played on my computer the sound is in good stereo. But when the file is burned to a DVD the sound is rather flat and doesn't sound the same as it did on the computer. A couple folks suggested to adjust the rendering or export or DVD burn setting's. But none of that seems to work or at least I'm not doing that right. If the settings have anything to do with the sound, then what settings should I use?
I use several video editing programs from Arcsoft, Magix, Windows Movie Maker to Adobe Premeir. I get the same results regardless what program I use.
Any suggestions?
Mark![]()
AVI, MPEG file -
Are you sure your computer audio isn't set with some kind of audio effects turned on?
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Need also expert advice about video and sound files!!
By vantechmag in forum EditingReplies: 8Last Post: 14th May 2009, 10:48 -
Advice Req: Filtering Audio Files For A Clearer Sound
By Teac23 in forum AudioReplies: 2Last Post: 27th Nov 2008, 09:43 -
I need some advice, problems with the sound becoming offtrack
By maverickboy2007 in forum Newbie / General discussionsReplies: 7Last Post: 16th Nov 2008, 05:04 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20
