Is there a way to change the bitrate in ConvertXtoDVD? With the 700MB to 1.4 GB avi's I tried with it, it encodes the audio bitrate as 256. I'd rather encode it at 192 (as I do when encoding WAV to 2-channel AC3). Is there a way to change it or is a higher audio bitrate necessary to convert a 44100 128 mp3 file to a 48000 AC3?
Results 1 to 10 of 10
you can change the audio bitrate in convertxto dvd. you can select the audio link and change the bitrate.you go to settings>audio>change the settings there > select audio br of your choice. encode>done.have a nice day.
ok,
not with the last version i tried.
so it's fairly new.
skimming through the changelog i suppose 3.2.0.44"I'll give you five dollars if you let me throw a rock at you" -
Yeah, unless they made it a new option on the latest version, i have never seen where you could change the bitrate of video or audio.....Originally Posted by ZQX
It would be nice though 8) -
I have the latest (registered) version 3.2.4.82. I cannot see any option to change audio bitrate under Setting/Audio?
Originally Posted by sumeshkriShow us a screen shotOriginally Posted by sumeshkri
Now i remember you can put in manually the target size of the final project but not put in a specific bitrate.
And you can change the audio format, 2.0, 5.1, mpeg audio...
But nothing at all on manually changing the audio bitrate
ERRATUM
i apologize all concerned for quoting false information. i took it for avidemux where we can adjust the adio bitrate. yes we cannot fix the audio or video bitrate in convertxtodvd. that is the main drawback of this software.
Change bitrate of LPCM 5.1 ch ( audio file after demuxing )
By wisitch in forum AudioReplies: 3Last Post: 8th Apr 2010, 13:09 -
change video bitrate
By Ogilvy in forum EditingReplies: 2Last Post: 3rd Jul 2008, 14:07 -
No change in bitrate (audio & video) after shrinking?
By moviebuff2 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2008, 01:34 -
ConvertXtoDVD - Can't change subtitles color
By Phil240 in forum Authoring (DVD)Replies: 5Last Post: 8th Dec 2007, 04:03 -
ConvertXtoDVD does it find optimal mpeg bitrate for you?
By supaguy in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 16:13
