Good afternoon all, I hope that I am posting this in the right section. My question is that when I download video in 1080i on my computer and save to the hard drive, during the playback it freezes up quite frequently. When downloading and saving a 720p its great. On the other end when I run movie trailers like from apple/quicktime in 1080p and view them it runs flawless. I have a nvidia 6800 video card with a P4 3.06ghz cpu and 4 gig of ram. My monitor is maxed out at 1920x1080. Anyone could help why I have this problem. Thanx all.
	I reject your reality
 and substitute my own.
 - Adam Savage -
 - Mythbusters -
	thats actually what i've been using because the files are in mkv format. I reject your reality
 - Adam Savage -
 - Mythbusters -
	Your computer isn't powerful enough to play 1080i from your harddrive,i had the same problem playing 1080i with a 3400 athlon 64,when i went to a an athlon 6000 x2 then it played smoothly. I think,therefore i am a hamster.
	You might also try Media Player Classic Home Cinema. It seems to work fine for MKV HD video.
 But you do need a fair amount of CPU power and a video card that can handle the format.
	i'll give it a try I reject your reality
 - Adam Savage -
 - Mythbusters -
	I'd recommend at least an nvidia 8400 series card for high def graphics. That should help a lot for smoother playback. Plus if you can swing it jump to a dual core processor. The improvement in performance is dramatic.Originally Posted by dynamix1Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  connecting computer for display/watching videosBy zamansoomro in forum Newbie / General discussionsReplies: 0Last Post: 16th Apr 2011, 17:05
  watching tv on my computerBy dylz in forum DVB / IPTVReplies: 2Last Post: 10th Jan 2011, 03:37
  Capturing VHS to computer and then watching on tv from dvdBy the_bear99 in forum EditingReplies: 2Last Post: 25th Sep 2010, 11:29
  computer restarts when watching a movie!By tomchook in forum Software PlayingReplies: 10Last Post: 17th Feb 2008, 21:56
  Watching Television on computerBy Enorats in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2007, 03:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
