what is a frame server and how do i make one so i can encode my fricken movie. thanks
Results 1 to 10 of 10
..and you would have to say to which software you want to frameserve
>>What is frameserve?
>>where are the FAQs ? -
i am stupid and i still cant figure this out what should i use with G-knot? im trying to go from svcd to avi/divx? thanks
If you have an Mpeg 2 codec installed just load your source SVCD into Virtual Dub and encode it as an DivX'd avi.
Look to the left under CONVERT. You'll mostly be working backwards as to what is being done throughout the page.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
I'm sorry for being unclear - by source SVCD - I mean the source clip
svcd.mpg~~~Spidey~~~
If you are using Gordian Knot, it already comes with the Frame Servers you need. It uses DVD2AVI and Avisynth. Perhaps you should try reading the Gordian Knot HOWTO on doom9.org ;)
http://www.doom9.org/divx4-avs-main.htm
Even better, maybe you should read the SVCD to DivX guide :o)
http://www.doom9.org/svcd2divx.htm
Let me know if you need some help. How many CD's is the SVCD?
Good Luck.
wh -
this is what i got when i did what it told me to do:
2/13/2002 6:12:09 PM: Job "Lord of the Rings " started.
o Encode WAV -> MP3: C:\LOTR\001_lotr MPA T01 DELAY 0ms.wav
o DivX4-First Pass: D:\Program Files\GordianKnot\DVD2AVI.exe
o DivX4-Second Pass: D:\Program Files\GordianKnot\DVD2AVI.exe
o Mux Audio.
End of Job 2 (Lord of the Rings ).
__________________________________________________ __________________________________________________ ___________________
Gordian Knot 0.23.0.17
Encoding Job Data:
Type: EncD4_Both
Number: 2
Name: Lord of the Rings
Platform: WinXP (5.1.2600).2
Files:
VirtualDubExe: D:\PROGRA~1\GORDIA~1\virtualdub\Virtualdub.exe
NandubExe: C:\lame\lame.exe
AviFinal: C:\LOTR\lotr.avi
AviMovie: C:\LOTR\lotr_Movie.avi
AviCredits: C:\LOTR\lotr_Credits.avi
MovieFS: D:\Program Files\GordianKnot\DVD2AVI.exe
CreditsFS:
Log : C:\LOTR\lotr.log
Stats: C:\LOTR\lotr.stats
Ecf :
Options:
Quality/DRF: 0
CreditsStart: 0
UseEcf: 0
CreditsIVTC: 0
CreditsAppend: 1
DeleteInterm.: 0
EnforceBitrate:0
AntiShit: 0
Calculator:
VideoSize: 1418135 kbyte.
Audio1Size: 1845531 kbyte.
Audio2Size: 0 kbyte.
Overhead: 20226 kbyte.
AviSize: 3283892 kbyte (3206 mbyte).
FilesSize: 0 kbyte.
TotalSize: 3283892 kbyte (3206 mbyte).
Interleaving: vbrmp3
Bitrate: 1084 k(=1000)Bits/s
Frames: 321069
FPS: 29.970
Duration: 2:58:33
Quality: 0.100 bits/(pixel*frame).
CompCheck3: 0.000 bits/(pixel*frame).
CompCheck4: 0.000 bits/(pixel*frame).
Resolution: 704 x 512
Audio 1:
mode: wav -> mp3
sourceFile: C:\LOTR\001_lotr MPA T01 DELAY 0ms.wav
wavFile: C:\LOTR\001_lotr MPA T01 DELAY 0ms.wav
mp3File: C:\LOTR\001_lotr MPA T01 DELAY 0ms_1.mp3
azid: "-z1 -b1 -c normall -L -3db "
lame: "--alt-present 160"
delay: 0
interval: 2
preload: 500
mux: 1
recalc: 1
deleteWav: 0
Audio 2:
none.
6:12:10 PM: Started Transcoding Audio.
6:12:10 PM: LAME: Encoding C:\LOTR\001_lotr MPA T01 DELAY 0ms.wav
Commandline: D:\PROGRA~1\GORDIA~1\lame.exe --alt-present 160 "C:\LOTR\001_lotr MPA T01 DELAY 0ms.wav" "C:\LOTR\001_lotr MPA T01 DELAY 0ms_1.mp3"
6:12:12 PM: Finished. Duration: 2 seconds.
6:12:12 PM: Audio Done.
6:12:12 PM: ERROR: MP3-File-Size is zero! Transcoding failed.
6:12:12 PM: ERROR: Will not recalculate bitrate! - Maybe you can add audio later...
6:12:12 PM: Audio 1, determined: 0 kb
6:12:12 PM: Audio 1, calc: 1845531 kb
Adding this script to D:\PROGRA~1\GORDIA~1\virtualdub\VirtualDub.jobs:
// $job "DivX4 First Pass"
// $input "D:\Program Files\GordianKnot\DVD2AVI.exe"
// $output "C:\LOTR\lotr.avi"
// $state 0
// $start_time 0 0
// $end_time 0 0
// $script
VirtualDub.Open("D:\\Program Files\\GordianKnot\\DVD2AVI.exe",0,0);
VirtualDub.audio.SetSource(0);
VirtualDub.audio.SetMode(0);
VirtualDub.audio.SetInterleave(1,0,0,0,0);
VirtualDub.audio.SetClipMode(1,1);
VirtualDub.audio.SetConversion(0,0,0,0,0);
VirtualDub.audio.SetVolume();
VirtualDub.audio.SetCompression();
VirtualDub.video.SetDepth(24,24);
VirtualDub.video.SetMode(1);
VirtualDub.video.SetFrameRate(0,1);
VirtualDub.video.SetIVTC(0,0,-1,0);
VirtualDub.video.SetRange(0,0);
VirtualDub.video.SetCompression(0x78766964,0,10000 ,0);
VirtualDub.video.SetCompData(316,"YIoQANAHAAAKAAAA FAAAACwBAAAMAAAAAgAAAAUAAAACAAAAKAAAAAAAAAAAAAAAAA AAAP////8BAAAAQzpcTE9UUlxsb3RyLmxvZwAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAZAA= ");
VirtualDub.video.filters.Clear();
VirtualDub.subset.Delete();
VirtualDub.SaveAVI("C:\\LOTR\\lotr.avi");
VirtualDub.Close();
// $endjob
// $done
6:12:12 PM: Started DivX4-First Pass: D:\Program Files\GordianKnot\DVD2AVI.exe
6:12:15 PM: Finished DivX4-First Pass. Duration: 2 seconds.
6:12:15 PM: Trying to open Log-file.
6:12:15 PM: Error: Could not open C:\LOTR\lotr.log
6:12:15 PM: Error: Could not count encoded Frames.
6:12:15 PM: Speed: 0.000 Frames per Second.
6:12:15 PM: WARNING: Number of counted frames differs from settings!
6:12:15 PM: WARNING: Settings: 321069
6:12:15 PM: WARNING: Counted: 0
6:12:15 PM: WARNING: Difference: 321069
6:12:15 PM: Correcting Bitrate...
6:12:15 PM: Original Bitrate = 1084 k(=1000)Bits/s
6:12:15 PM: ERROR: Correction impossible.
6:12:15 PM: Now encoding at 1084 k(=1000)Bits/s
// $job "DivX4 Second Pass"
// $state 0
// $start_time 0 0
// $end_time 0 0
// $script
VirtualDub.video.SetCompData(316,"YIoQANAHAAAKAAAA FAAAACwBAAAMAAAAAgAAAAUAAAADAAAAKAAAAAAAAAAAAAAAAA AAAP////8BAAAAQzpcTE9UUlxsb3RyLmxvZwAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAZAA= ");
VirtualDub.Close();
// $endjob
// $done
6:12:15 PM: Started DivX4-Second Pass: D:\Program Files\GordianKnot\DVD2AVI.exe
6:12:15 PM: Finished DivX4-Second Pass. Duration: 0 seconds.
// $job "DivX4 Append"
// $input "C:\LOTR\lotr_Movie.avi"
// $state 0
// $start_time 0 0
// $end_time 0 0
// $script
VirtualDub.Open("C:\\LOTR\\lotr_Movie.avi",0,0);
VirtualDub.video.SetMode(0);
VirtualDub.video.SetCompression();
VirtualDub.Close();
// $endjob
// $done
6:12:15 PM: Started Appending Credits: C:\LOTR\lotr_Movie.avi
6:12:16 PM: Finished Appending Credits. Duration: 0 seconds.
6:12:16 PM: Done.
6:12:16 PM: Movie = C:\LOTR\lotr.avi
Total Encoding Time: 6 seconds.
2/13/2002 6:12:16 PM: Job "Lord of the Rings " finished.
im not sure what to do so i think im gonna quit.
Recording Stream on local computer : Streaming Server Wowza Media Server 2
By iLove in forum Video Streaming DownloadingReplies: 2Last Post: 19th Apr 2012, 16:25 -
Hardware Frame Server?
By therock003 in forum Newbie / General discussionsReplies: 0Last Post: 27th Nov 2011, 08:51 -
Mplayer as a frame server? Pipe to file?
By RogerTango in forum Video ConversionReplies: 2Last Post: 10th Sep 2011, 09:23 -
frame server doesn't work in Premiere CS4?
By ivanadit in forum EditingReplies: 0Last Post: 6th Jan 2009, 13:46 -
install Win2008 Server STD Government Volume License on Server with no O/S
By retroborg in forum ComputerReplies: 5Last Post: 11th Nov 2008, 09:18
