Hi,
I first tried HDTV2DVD Version 0.4 yesterday on my Vista Home Premium 32b PC to convert a TS-file (H.264 HD-Pay-TV) to DVD. But it was not possible to insert the TS-file into the programm (I used drag&drop).
Does it not work with vista, or do I have only a test-version? Thanks for any help.
Regards
feilofix
You could try HDTV2Mpeg2 for converting a TS (transport stream) into a standard MPEG2. Then go from there. BTW, HDTV2Mpeg2 has basic editing capability and can scan for adverts.
Good luck.
Pull! Bang! Darn!
HDTV2DVD will not let me drag and drop .ts file into "assests"
By Dollybono in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Mar 2009, 05:38 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 19:09 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 01:59 -
HDTV2DVD - Any way to prevent .MPG file from getting created?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 8th Oct 2007, 20:00 -
Trying to load .ts file to DVCD2DVD
By movieman123 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 18th Sep 2007, 20:37
