I've been using Fairuse Wizard with the Speed Setting, and dragging the slider all the way to the right (quality).
I'd like to experiment with the "Codec Setting." So on the pull-down I choose "Codec Setting" and then I can click on the setting button and make all sorts of changes for DIVX. When I finally click okay and I'm back in the Fairuse Wizard window, it doesn't really seem like any of the settings I've chosen have stuck. For example, I might have made all sorts of bitrate changes within the settings window, yet when I come back to Fairuse Wizard it looks like it is at the default file size of 700 mb (yes I have the full version).
So how can I make use of the Codec Settings?
Thank you.
Results 1 to 1 of 1
I get a "could not load codec settings" with Fairuse Wizard
By felix in forum DVD RippingReplies: 3Last Post: 29th Apr 2011, 11:10 -
Fairuse wizard "Resolution/AR" question!
By UnD3R0aTh in forum DVD RippingReplies: 6Last Post: 18th Mar 2010, 06:14 -
FairUse Wizard, quantizer and codec settings
By 2dpikke in forum DVD RippingReplies: 2Last Post: 25th Feb 2010, 08:03 -
Fairuse Wizard settings - looking for rules of thumb
By JamesNG in forum DVD RippingReplies: 3Last Post: 29th Jul 2008, 20:01 -
Fairuse Wizard full version and adware "win32.rabio"
By ricardouk in forum DVD RippingReplies: 2Last Post: 13th Mar 2008, 10:56
