Ok
So I have a DVD in which has 3 split VOB files. I used DVD Decryptor to rip the VOBs, then I used Gordian Knot to reencode the VOBs to one XVID video file in an MKV container.
What I want to do is take the XVID video stream and pull it out of the MKV, cut it into 3 smaller pieces, as there are 3 episodes in the one stream, then put those back in their own MKV container.
As I was typing this I realized that I will have to split the audio files as well so this might not be the best way to do this.
Does anyone have any suggestions as to how this could be acheived?
Video is still currently encoding. About 95% on first pass. As soon as its done, I will try avidemux and see what happens. I opened the program, and I dont know if it will do anything with the MKV itself though. Since the MKV is a container, is there a way to just pull something out of the MKV kind of like dragging it out of a folder? Or will avidemux actually work with the MKV ?
Yes avidemux supports .mkv
To answer your other question: yes, you can extract contents from .mkv with mkvextractgui
It would be easier input your decrypted vob's into avidemux and use it to do everything. It will append the vob's into 1 big movie, but you can encode sections with xvid using the mark in/mark out (you can even use x264 or dozens of other choices), or encode the whole thing
If you already have an encoded xvid in .mkv, use Baldrick's suggestion which is very easy to do as well. -
You can split without separate muxing and demuxing simply by using MKVMergeGUI, included in the mvkmerge package. It handles MKV files in a much more stable manner than Avidemux. Just figure out the two times at which you want to separate the files and place the values, separate by a comma, in the "Timecodes" field of the "Splitting" section of the "Global" tab.
So kind of not what I was looking for.
The DVD is split into 3 VOBs. 2 are 1GB and the last one is about 800Mb. If I open the IFO for those in VOBsub Rip, it reads them as if it sees the subtitle stream, but they are labeled as undefined. Does that happen sometimes?
Should the subtitle stream be seperate for each episode on the DVD? Is there a guide or something like advanced techniques to pulling subtitles out of a DVD ?
How do I make my .mkv files smaller?
By nzdreamer55 in forum Newbie / General discussionsReplies: 6Last Post: 14th Sep 2011, 07:12 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 02:53 -
Converting large AVI files to smaller MKV
By vipertongn in forum Video ConversionReplies: 3Last Post: 26th Jan 2010, 19:07 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23 -
re encoding MKV files with subs to smaller file sizes with min qual. loss
By malakov08 in forum MacReplies: 1Last Post: 4th Apr 2009, 03:06
