How do I get menus I created to show up in Adobe Premiere Pro 2.0 Pls can SomeOne Help
	1) Not enough information..what is the file you are trying to import? a JPG? A .psd file?
 2) If you're trying to make a DVD Menu you're in the wrong application. premiere is an editor, not an authoring application.
	Premiere Pro 2 has a simple timeline to DVD mode only intended for quick previews. (see manual) Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Well I've made some DVD menus of my own. Premiere Pro 2.0 has the ability put them as the frontrun for a DVD movie Premiere Pro comes with some DVD templates about 2. I would like to use my own custom templates for my short movies. I have found a tutorial that says put them in a custom folder did that still not work. All menus are in PSD format as which the ones in Premiere Pro
	Premiere is designed mainly for editing the movie content itself. Encore is Adobe's tool for DVD authoring. You should really be doing your navigation menus with your DVD authoring software, not Premiere.
  Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22
  Adobe Premiere Pro CS3 & Vegas Pro helpBy KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 23:52
  SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00
  logitech pro 9000 captured video to premiere pro CS3?By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27
  Magix Movie Edit Pro Menus and Sub-menusBy gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 11:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
