Hi,
I have the choice between these 3 mini DV PAL camcorders. But I don't know which one is the best in all conditions (light scenes , dark scenes,....). It's for occasional use (holidays, city trips,...), not intensive use. I would film about 5 or 6 hours max of video per year.
I don't find any review or advanced tests for these camcorders.
So where can I find some tests or advices ?
I have choice between:
Sony DCR-HC 51
Sony DCR-HC 53
JVC GR-D820
Here is the manual for the 2 sony models: (unfortunately in French)
http://www.mgmi.fr/docs/pdfprod/MUDCR-HC51E.pdf
Seems like the 53 Has a USB connection which the 51 doesn't, so you can probably use it as a webcam too.
Don't know about the JVC -
I always suggest getting a cam with a LANC for using a remote control on the tripod. This way, you can get semi-professional pans, tilts, and zooms. Of course, if you're just shooting handheld, there's no need.
www.camcorderinfo.com -
Perhaps it would be cheaper to rent a camera then. -
The HV20 price is too much for my use.Originally Posted by MJA
Maybe, but I don't always transfer my tapes directly when I come back from holidays.Originally Posted by Soopafresh -
Sony DCR-HC51E
http://www.vimeo.com/1152009
Do a search on vimeo for your other cameras
Aiptek A-HD Plus
http://www.vimeo.com/842303
Even better, the Z500 which shoots at 1080p
http://www.tomshardware.com/reviews/cebit-2008,1900-18.html
Or the lower priced AHD 300
http://nexus404.com/Blog/2008/08/10/aiptek-pocketdv-ahd-300-1080p-high-definition-camc...dhc-camcorder/
Mini dv camcorder to computer
By ccastell88 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 21st Jul 2011, 07:37 -
Question: Best Mini DV Camcorder Ever
By cbehr91 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 20th Jul 2010, 18:28 -
Help to choose the right camcorder for internet video
By kjemmo in forum Newbie / General discussionsReplies: 4Last Post: 7th Sep 2007, 17:15 -
How to choose a camcorder?
By beavereater in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 26th Jul 2007, 08:14 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 03:11
