Hello, All.
The strangest thing has been happening to my PC. 5 or 6 times in the past couple weeks, only while in the midst of encoding video/audio(using either ConvertX, TMPGEnc XPress or Womble) the system just powers-down on its own. And I don't mean "shutting down" or rebooting. I mean like pulling the plug from the wall shutdown. Poof! No power. And to make it even stranger, the power light on the CPU stays on after this happens, after there is no power. Meaning I must then actually unplug the CPU power line or flick off the power strip in order to restart the computer.
And when I do turn it back on, everything is fine. No damage. (Of course the encoded files it was working on are screwed.) This has only happened during video/audio encoding/muxing and never at any other time. And only 5 or 6 times during encoding. The majority of encodes finish fine with no trouble.
What goes on here??? Codecs, type of video or audio file, virus, memory?
Thanks in advance,
M22
mine did the same when it was overheating...check the fan, temps, vents, etc.
Either overheating, or your power supply is starting to fail. It may not be able to handle the processing load.
Bizarre vertical lines
By Asterra in forum Capturing and VCRReplies: 55Last Post: 17th Apr 2011, 21:46 -
Bizarre sync issue
By cinesimon in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2011, 16:44 -
Bizarre error using TMPGEnc 4.0 Xpress?
By the colonel in forum Video ConversionReplies: 1Last Post: 29th May 2010, 20:30 -
Bizarre Pan. ES20 Issue
By bhartmann10 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 3rd Aug 2007, 14:12 -
Bizarre attempt to buy DvdFab
By VegasBud in forum ComputerReplies: 1Last Post: 8th Jul 2007, 20:54
