Hi,
I possess a cablebox HD (Scientific Atlanta Explorer 8455 DVB-C) and various video recorders S-VHS. But the problem and what this cablebox does not allow to take out in Video but in YPbPr, RGB, composite or HDMI.
I did not manage to find a schema to make a converter YPbPr towards Video. Converter RGBHV towards Video is expensive and I am not even on the quality of conversion. Thus I think of buying a Professional video recorder S-VHS with entry YpbPr but I do not find there.
The only model which I found it is Sony SVO-5800 but that has only an out YpbPr.
I would like to stay in VHS.
I also possess a video recorder W-VHS JVC which is equipped with an entry YpbPr but I reserve him for the HD.
Please help me to find the best solution.
Thanks,
PS: excuse-me for my bad english.
Are you sure you can't configure the SCART output of that cable box for S-Video?
Here in the Netherlands one of our DTV providers is also using this Cisco/Scientific Atlanta Explorer 8455 cable box and it has the option to configure at least one of the SCART outputs for RGB/Composite and S-Video.
Alo you want that cablebox to output "video", you mean composite video (CVBS) or S-Video?
Almost every settopbox in Europe outputs RGB and composite video at the same time over the SCART outputs.
If you really need to convert the signal from that cablebox a alternative option would be to use a (cheap?) DVDrecorder.
Most of those devices can take the SCART RGB signal an convert it to composite/S-Video/component and even HDMI if you have a recent one.
Here I am using a older (gifted, repaired) Panasonic DVDrecorder for exact that same purpose. -
Yes I am sure.
My provider HDTV is “numéricable” and they installed them “OS” there which does not allow to select output S-Video on scart output.
Before, I possessed a cablebox not HD and it was effectively possible to configure the scart output in S-Video.
I called up them, but they did not foresee him, because considered too "obsolete".
But I have can be via the port USB it’s possible to modify “OS”?
What do you think?
Whom could I address?
I had not thought of the DVD to re-cord, it is a very good idea, but I am a follower of VCR and I do not think of buying it, but thank you. -
Originally Posted by saigo
Here even the cable company has crippled the HD component connection to only output PAL SD.
But at least the SCART (both) connections should output a normal composite signal (CVBS), you could use that to record to (S)VHS?
That output should still have enough quality for (S)VHS recording.
You can't change the OS/firmware yourself, specially not with the USB connection
Why would you buy a very expensive VCR with YpbPr input?
I can see no good justification for that in these days. -
Originally Posted by The_Doman
But there is small converter HDMI-YUV …
By pleasure for the beautiful material, the numeric does not really interest me.
I like very much the VCR mechanics , it's a passion!
I thought a BETACAM-SP VCR , there is of very beautiful machine, a little big
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 322Last Post: 18th Mar 2025, 14:04 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19 -
YpbPr on Hdtv only shows pink screen.
By tiagirl in forum Newbie / General discussionsReplies: 4Last Post: 14th Apr 2008, 12:18
