HI
I have a short M2V clip and I need to do one of these two things:
1) to cut a M2V file
2) to 'edit' some single frames as images in order to 'erase' some writings
The first thing is simple, I suppose, but I don't know which software to use (nor how).
The second (more interesting) thing is more complex I think, but I suppose it should be possible to somehow 'demux' the single frames, edit the ones I need to edit, then 'assemble' again the clip (with the same framerate, length, etc.).
Is it possible?
How?
Thanks in advance![]()
VideoRedo or Womble Mpeg Video Wizard would be my recommendations.
If you remove frames you will be changing the length of the video, and therefore introducing audio sync issues over time.Read my blog here.
echoing guns1inger, MPEG Video Wizard will do these things fine. You will want to put both the video and the audio track into thet video wizard application and make sure you make the same cuts at the same places on both tracks, then when you encode the file you'll have the audio/video where it should be.
Extracting frames from single PGM file
By lchen in forum MacReplies: 0Last Post: 18th Jun 2010, 05:49 -
IVTC a vob/m2v file before FCP editing
By kmxe in forum MacReplies: 18Last Post: 18th Mar 2010, 03:15 -
Cutting Mp4 between I-frames, replacing some frames
By eymerich in forum EditingReplies: 4Last Post: 29th Jul 2009, 09:41 -
How to remove a single or more frames from a DVD
By justmehere in forum Authoring (DVD)Replies: 2Last Post: 22nd Apr 2008, 13:06 -
m2v file stops to display frames during playing
By Fendervr in forum Video ConversionReplies: 2Last Post: 22nd Aug 2007, 13:43
