how do you do this?
Is it better to use the AC3 5.1 or 2.0 source track for an XviD using VBR MP3 audio? I can't really find a definitive answer. Was going to backup a few of my own DVDs and want to get the best quality possible without encoding to AC3 audio.
If your DVD has both DD 5.1 and DD 2.0 tracks, and you want to use one to convert to stereo MP3, then use the DD 2.0 track. But if you're talking about backing up your DVDs to DVD, then MP3 is no good. If you're backing them up to AVI or somesuch, then MP3 is fine.
If you are backing up DVD to DVD than mp3 is not supported for that format.
If you are doing DVD to Xvid(DivX) than mp3 is fine, but that format support ac3 also. File will be much larger specially if you use 5.1.
To convert ac3 to mp3 you will end up with stereo one way or the other, so it make no difference what ac3 audio you will chose for conversion.
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 05:18 -
Mainconcept Reference - 2ch audio
By ranosb in forum Video ConversionReplies: 2Last Post: 11th May 2009, 07:10 -
MKV to MP4 for PS3 with dual-audio (2ch AAC + 6ch AC3)
By sexyclient in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Dec 2008, 23:01 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19 -
5.1 AC3 to 2ch mp3 error's in VDubMod
By Sykotik in forum DVD RippingReplies: 0Last Post: 20th Oct 2007, 07:53
