I've been using GomPlayer v2.1.9 for the past few months and it worked great. Now all of a sudden it won't play DVD's I've recorded on my DVD recorder (Pioneer) if I they were recorded in EP or LP mode. I will see horizontal lines as if the horizontal sync is screwed up (if you can remember back to the old TV days). GOM works fine when playing an SP video, just not LP or EP. My Intervideo player can play the DVD's just fine and so can my other machine that is using GOM.
I tried uninstalling and re-installing GOM, but the problem persists.
Any idea on how to fix it?
TIA
Brent![]()
Yes, I've downloaded the latest version, uninstalled the previous version, and installed the new version. There is no joy in Mudville.
GOM played the same videos fine for months, but now playing DVD's recorded in EP/LP mode are now just scrambled horizontal lines (SP works fine). Another video player plays the same DVD just fine, and GOM works on another machine just fine with the same DVD. I would have thought uninstalling and re-installing would have fixed the problem.
Turning down my video hardware accelerator seems to get it to work for a while. Maybe it was caused by a MS update I took?
Brent -
For me i had the same problem now. I never updated Windows before, but after few updates GOM doesnt play any kind of video. I ll try to update it to SP3 or deinstall the latest updates so.
GOM has also stopped playing EP recorded DVD's on my other computer. So it must be some sort of update that caused the problem. It will still play SP recorded videos that I made on my video recorder, just not EP DVD's. It must be some sort of codec problem. I'm not willing to uninstall the Windows updates because I need the security patches. So I'll look for another player I guess. Too bad because GOM was quite good.
Brent
Horizontal black lines in exported HD video
By progressive_pete in forum Video ConversionReplies: 5Last Post: 25th Jan 2010, 08:36 -
Pinnacle Studio produces horizontal lines on encoded video
By Grunberg in forum Video ConversionReplies: 2Last Post: 30th Jan 2008, 19:45 -
Bright horizontal random lines in 8 mm Camcorder Video
By axhack in forum RestorationReplies: 4Last Post: 11th Jan 2008, 22:05 -
Horizontal Lines making video unbearable
By Fatalize in forum Capturing and VCRReplies: 5Last Post: 20th Sep 2007, 13:27 -
Horizontal lines on video playback with vista
By richard.fisher in forum Software PlayingReplies: 7Last Post: 4th Jun 2007, 09:48
