Windows does not seem to be recognizing my camera HV20. I get an error message each time, even though checked with Canon that there is no problem from the camera's side. He questioned whether there is something in Windows XP that is causing the problem. Disconnected printer and other possible hardware that could conflict.
Results 1 to 10 of 10
http://www.kiva.org/about -
The message simply stated something to the effect that it did not recognize an external device. I was using movie maker at first. I have downloaded WinDV, though not tried it. Told by Canon guy this was not appropriate? for still photos? I am connected via firewire IEEE1394 to my knowledge but dont' know how to check other than camera says it is connected. Don't know what HDVsplit is. Is that other software. Not sure if the moviemaker is working but it does open.
Exact, Precise, AND COMPLETE text of the error msg? Screen shot would be helpful.
Has this camera EVER worked on this PC?
Do you have another PC available for testing?
Camera in correct mode?
Is this PC a laptop?
Are you using the cable that came with the camera?
Possible incompatible Firewire port. -
Are you shooting HDV? I don't think Windows Movie Maker is going to handle that.
Was there a disc that came with your camera? Usually, such a disc will contain the necessary Windows driver for it. Have you checked out your Device Manager to see if your camera is showing up? Your issue may be a simple driver problem.
What does your owner's manual say about capturing through firewire?
And did you read Nelson37's questions? Your camera should be in playback/VCR mode.
And like edDV said, WinDV is only for standard definition DV. If you shot in HDV, then you would need to capture with HDVsplit. (It lights up in red in these posts -- just click on it. Or else, find it in this site's Tools section.) -
How do I know. This computer, though "relatively old" was suppose to be able to deal with video editing, has 4 pt Firewire port.Originally Posted by Nelson37
Can I just download this HVsplit? Would other software potentially work? I just downloaded AVS videoeditor 4 but did not purchase until I could be sure what I was getting so have not tried it. Thanks for help.Originally Posted by filmboss80
HDV Split: https://www.videohelp.com/tools/HDVSplit
Click on the part that says "Download." It is free. Got it?
Reading your "Computer Details" it looks like you have insufficient RAM memory, insufficient hard drive space, and a borderline CPU for HDV. Even if it can handle "video editing" that may apply to standard definition DV. If you're shooting the high-def stuff, it will choke your machine.
Know your video format before you choose your editor. If you shoot HDV, you must use a compatible video editor. Vegas comes to mind.
Video capture, editing & redndering in 1680x1050 - BIG PROBLEMS
By casparticus in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2011, 16:57 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
video capture problems in ulead videostudio 11
By scott114 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2008, 15:49 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18
