Are there any programs out there that will upmix a stereo (demuxed MPEG2) stream to AC3 5.1? I know that it won't be true surround sound as the information simply isn't there in the stereo stream, but it should be possible to improve on the basic stereo. Or is it better to just leave it as stereo and use a suround simulation mode on my amplifier?
Sláinte
midders
In my opinion its not worth the effort.
Chances are it probably has dolby pro logic encoded on the stereo signal. If it does then your stereo will do a decent job of surround simulation. If your stereo has Dolby Pro Logic 2 it will do even better since it will simulate 5.1 from any source. Where as Dolby Pro Logic is much more limited but at least has rear effects.
EDIT - by the way yes there are programs that can do it. Higher end video editing and audio editing apps have the feature. Just don't expect the feature in the basic versions of most editing packages.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Read my blog here.
stereo downmix: surround vs surround 2
By codemaster in forum AudioReplies: 7Last Post: 29th Aug 2012, 11:06 -
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 19:05 -
DTS encoding ( Stereo to surround ) ?
By 3thman in forum AudioReplies: 6Last Post: 6th Feb 2010, 06:06 -
"stereo" file (two channel signal) - Surround or Stereo?
By zee944 in forum AudioReplies: 0Last Post: 4th Sep 2009, 05:53 -
2.0 stereo vs surround with 2 speakers
By ecc in forum AudioReplies: 8Last Post: 13th Jun 2007, 09:58
