I have a number of .flv car mechanic movie files which because I can't control very well with the vlc movie player (like forward movement) and because they will not play in a universal player like windows media player, I want to convert them to either the .avi format or maybe the .mp4 format. I think the .mp4 format results in a smaller file size but I don't know if it is a good format to convert to. So I am leaning toward the .avi format unless someone here advises otherwise.
I am using the gvc video converter. It lets you change the number of frames and kb in the sound . Since all the videos include speech only, I thought I would set it on 64kb mono since I don't see how it would help to have speech in stereo nor the quality kb be that high.
For frames I thought I would set it on 29. (is it .97) frames. I just want to use these movie files on my computer for reference but would like to be able to convert them to DVD format if the need should ever arise.
Am I on the right track?
Download the Klite codec pack and the .flv files should play in Windows Media Player.
http://www.filehippo.com/download_klite_codec_pack/ -
the last thing anyone should do is install a codec "pack". they cause more problems then malware. just as hard to get rid of also.
only install needed codecs individually.--
What are you talking about ??? Codec Packs have never caused me any problems..and it is easy to remove.Originally Posted by aedipuss
If you're simply looking for a way to play them back easily, FLVPlayer is a good free software for doing so.
MPC-HC should be just as easy for playing also
I'd use MediaCoder for re-encoding
NO codec packs, NO way...imo
100+ of .avi files convert to .flv
By pribl in forum Newbie / General discussionsReplies: 1Last Post: 6th Nov 2011, 08:14 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
please suggest a prog to convert flv files to avi
By lurky in forum Video ConversionReplies: 1Last Post: 13th Aug 2008, 00:12 -
Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVI
By videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 00:14 -
how convert avi video files to mp4
By Shotobits in forum Video ConversionReplies: 14Last Post: 9th Jun 2007, 02:26
