Hi i've been using svcd2dvd for years now and love it however i seem to have a fault which i can't fix and was wonddering if anyone could help, below are the details, however i have recently & some what stupidly installed SP3 for XP i was wondering if this might be the cause?? i have two errors 1) on preview of my menu it states that svcd is unable to launch my default dvd player. 2) the program is not encoding fully when i go to burn the vob files with nero a error comes up saying incompatible vob file.. any help would be wicked....
************** Exception Text **************
System.IO.IOException: The process cannot access the file 'C:\Documents and Settings\Pauline\Local Settings\Application Data\Badger I.T\SVCD2DVD 2.5\2.5.3600.0\menu\VIDEO_TS\VIDEO_TS.IFO' because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.Delete(String path)
at x3284ccece41ee22b.xe679539bc4bbd8b5.xfeff58ae51b05 fd0(String xd168ac2ed64c4662)
at x3284ccece41ee22b.xe679539bc4bbd8b5.x865d1dce05e7a 87c(String xc7faa4629ea73ace, Boolean x1ebdb8fb1e9908a0)
at x3284ccece41ee22b.x210ff09a2516b1a7.x3bae72ab2c7b4 5fc(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at DevComponents.DotNetBar.SideBar.GT(BaseItem 95J)
at DevComponents.DotNetBar.BaseItem.RaiseClick(eEvent Source source)
at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBarPanelItem.InternalM ouseUp(MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBar.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.SideBar.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SVCD2DVD
Assembly Version: 2.5.3600.0
Win32 Version: 2.5.3600.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/SVCD2DVD.exe
DevComponents.DotNetBar2
Assembly Version: 7.0.0.3
Win32 Version: 7.0.0.3
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/DevComponents.DotNetBar2.DLL
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Deployment
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/Interop.QuartzTypeLib.DLL
System.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
	Service pack 3 has been causing some file permission issues:
 https://forum.videohelp.com/topic355545.html
 Don't use Nero to burn, use IMGBurn.Dwight
 "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
 - Herm Albright
 www.martialconcepts.com
	Also:
 1) You need a player associated with .ifo files to preview menus. See https://forum.videohelp.com/topic356082.html#1883954
 2) I agree with Jikchung: use ImgBurn. Download it and set it in the Burning Settings.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
  How to Convert VOB file from DVD with ignore read errorsBy designbuyers in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:17
  Errors in .VOB file burning as Data CDBy misterbean in forum Newbie / General discussionsReplies: 0Last Post: 8th Apr 2008, 02:31
  spumux & dvdauthor. No errors, but no subs eitherBy bepaald in forum LinuxReplies: 5Last Post: 29th Mar 2008, 16:54
  burning errors in nero & tmgenc dvd3By brushuk in forum Authoring (DVD)Replies: 2Last Post: 13th Mar 2008, 12:23
  check a DVD for errors/read errors?By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
