Hello all. I have a very frustrating issue. I have a Panasonic SDR-H40 HDD Camcorder. Whenever I copy my video files to my PC, they have no sound playback. Now they play sound fine when you watch them on the camcorder, or even when you preview them using the included video software. But when they are transfered to the PC, and played back (I use Windows Media Player), there is no sound. What do I do? I have about 5 months of footage on the camcorder, and never bothered to try transfering it until now to make some DVDs with the footage. Yes, my volume is up and the player is not on mute. The files are in MPEG format. Please help!
The audio is most likely AC3 (Dolby Digital), which you can confirm with g-spot or media info.
Try installing AC3 ACM Decompressor and see if you can hear anythingRead my blog here.
Thanks for the quick response! I installed the AC3 file you said, but I still hear nothing. I right clicked the .inf file, and installed. Should I have done anything more?
Oh the sound does work in my Nero Vision software that I use to make my DVDs so thats good! But no luck on media player. But it working with the Nero is most important. Thanks.
Stop using Windows media PLayer ? It is not a great player to begin with. Try VLC or The KM Player, which support a wide variety of audio and video codecs natively.
Read my blog here.
dvd copied from HDD wont work on other players or computer??
By wundahoss in forum Authoring (DVD)Replies: 1Last Post: 8th Nov 2010, 17:34 -
recover *.mts files from external HDD ..tried restoring hdd software
By ravistudios in forum RestorationReplies: 0Last Post: 18th Mar 2010, 13:24 -
Lacie LaCinema Premier no sound when playing sony camcorder files
By ravisinha in forum Video ConversionReplies: 0Last Post: 7th Mar 2009, 03:35 -
HDD VS Flash VS miniDV camcorder. Which is better?
By vid83 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Dec 2008, 10:11 -
Which is good HDD camcorder or DV camcorder?
By tapal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Sep 2008, 04:09
