I have been using adobe premiere. i have a crawling text that i would like to make shake halfway thru. is it possible to make an effect like this in premiere
thanks
You don't say whether the text is a separate layer or whether it is already embedded in the background. If it's a separate layer you can do as indicated below for the whole video. If it's part of the background the background will need to be uniform colour (otherwise extremely complicated editing required).
Method 1 - Click the video on the track and use the Effect Controls/Motion to jiggle the whole video (may need to enlarge video slightly or match background colour to video background (to prevent unwanted background colour showing through at edges as video jiggles).
Method 2 - Make a still frame capture, create jiggled frames in a graphic editor and create jiggled portion in Premiere by pasting frames back on video to form a sequence (this method depends on how your text is crawling).
How to Add Text Effects and Unicode Characters to MPEG-4 Subtitles
By PBear in forum User guidesReplies: 9Last Post: 20th Sep 2012, 09:15 -
After Effects: Text Disappears..
By Coldkilla9 in forum Newbie / General discussionsReplies: 1Last Post: 29th Oct 2011, 14:09 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
Free software to create animations or effects
By cd090580 in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2009, 06:09 -
which applications can be used to create video special effects?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 24th Nov 2008, 07:26
