Yes, I know old piece of hardware...![]()
Is anyone on this forum still using it with W95/98?
I don't have config troubles but still a lot of questions...
System: (yes, the Buz does work with newer systems!)
Asus CUSL2 mobo
CelII 566 @ 952![]()
Hercules Geforce 2MX (AGP)
256MB PC133
71GB total HD space
The Buz
Regards,
Manuel.
I'm still using mine.
Gigabyte 6vxc7-4a
P3 - 512MB RAM
80 GB WD hard drive
Windows ME
SB Live -
Great! So I can start asking those silly questions:
Do you (or are you able to) use nonstd capture resolutions in VDUB? (ex 480*576 or 400*300)
When not using one of the std res - 720*576 or 352*288 - it drops
frames like hell in my PAL-world...
Do you capture in MJPEG, RGB24, YUV or something else?
Are you able to capture in 720*576 25fps when not using MJPEG? If i use higher capture res than 352 or 360 * 288 it drops
frames like hell with any compression codec...
Is there an new driver besides V1.3?
Questions...questions...
Any input appreciated!
Manuel. -
I still use mine. Get great quality captures using AVI_IO in Full PAL (720x576) or half PAL (352x288). Only downside is the disc space. :cry:
I use the Morgan MJPEG codec, as I had a lot of crashes with the Buz ones.
I have not succesfully captured with non-standard resolutions or without MJPEG.
As far as I remember I am using 1.3 drivers - not aware of any later ones. Win2K/XP drivers would be nice so that I could update my OS!
Cheers,
Bill
System:
Athlon 1GHz, 512 MB RAM
Gigabyte 7ZX motherboard
20+60 GB 7200 rpm drives
Windows ME
On board SB128 sound card
iOmega 1tb harddrive fail??? plz help!!!
By NateDizzle in forum Media Center PC / MediaCentersReplies: 8Last Post: 3rd Dec 2011, 16:57 -
x264 and Iomega ScreenPlay Director HD 1TB
By Filiprino in forum Video ConversionReplies: 0Last Post: 21st Jul 2010, 18:21 -
Iomega ScreenPlay Multimedia-drive
By Ogilvy in forum Media Center PC / MediaCentersReplies: 2Last Post: 23rd Jan 2010, 09:43 -
trouble with Iomega ego portable driveS
By sdsumike619 in forum ComputerReplies: 4Last Post: 7th Oct 2009, 08:40 -
Iomega Screenplay Media Drive
By Trollheart in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Mar 2008, 18:18
