    Aug 2008
    I need some help to rip a subtitle from a dvd.
    I use subrip when im trying to rip the subtitle, the problem is that subrip doesn´t find the language that I want.
    I can only find English and German subtitles....but I want the Swedish subtitle ....and yes, I´ve cheched the dvd and there are Swedish subtitles on the dvd. :P
    So I´m a bit confused that subrip don´t find the subtitle.
    Are there any other software that can rip subtitle from a dvd?....or are there any specific config. in subrip that I´ve missed?
    Sry for my bad English :P
    Best regards: manutd
    Aug 2008
    Worked like a charm!
    Thanks alot!
    Eller ska jag säga tack kanske :P
