These messages are getting out of sync. The seller made the swap but it had a bent pin so I sent it back to be replaced. I am in a wait state at the moment.
Results 31 to 36 of 36
To lacywest:
The images that you posted do appear to be what I'm looking for. how significant is the code SL6HL which appears on your image? -
Well the search is over. The winner is me. I replaced a Celeron 1.8 with a Pentium 4 2.8 with absolute smoothness. When I first booted up the BIOS came on and wanted me to verify that the CPu speed had been changed. I said yes and it took off.
Thanks to everyone that followed this thread. The case is now closed. -
absolutely, as long as the motherboard supports both types of cpu, then just plug in and go, i've done this numerous times on both amd and intel platforms, you shouldn't even have to go into the bios.Originally Posted by mysts
Enjoy!"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
How significant ? ..... Well ... I figured it means that cpu gets that code ... different speeds get another code ...Originally Posted by mysts
Same cpu different speed ... SL6RZ ... is 2.4 GHZ ... socket 478
The SL6RZ came out of a HP D510C ... I put in a 2.66 GHZ ... from a HP D530C [dont know the code it is already mounted and sent out .... sold the PC on Ebay]
cpu upgrade
By hudsonf in forum ComputerReplies: 25Last Post: 20th Apr 2012, 10:15 -
CPU Question
By Datson in forum Video ConversionReplies: 5Last Post: 25th Jan 2012, 08:02 -
CPU upgrade possibility
By zzyzzx in forum ComputerReplies: 10Last Post: 2nd Feb 2011, 18:12 -
BIOS Question regarding new CPU
By ron spencer in forum ComputerReplies: 3Last Post: 4th Jun 2009, 09:23 -
cpu upgrade for 1080p mkv files?
By mjd113 in forum Media Center PC / MediaCentersReplies: 4Last Post: 27th Jan 2008, 15:51
