I saw screenshots of high quality, dvds, before and after the noise removal, and the pictures looked, perfect, can someone tell me, how do i find such a program?
What type of noise? You would have to better describe it, or post a screen shot that shows it. To reduce noise, you use a filter suited to your particular problem. However, filters are made to remove something, and you may lose video quality in the process.
Unless you start with a high quality source you may not see much improvement.
I usually extract the video file from the DVD with a program like VOB2MPG to create a single MPEG file of the video. There aren't many filters that work well with MPGs, so I convert to a AVI type format for advanced filtering. Most often DV-AVI, but other formats, like HuffyUV are lower loss, but take up a lot of hard drive space.
I use Virtual Dub as it has lots of filters available. AVISynth is a better program, but a bit harder to learn. After filtering, I re-encode to MPEG, then reauthor. That's two encodes, with each one having some quality loss. That's why a high quality source helps. Otherwise you may end up with a 'clean' video of very low quality.
Lots of other ways to do this. Look in our Restoration Forum for some ideas. -
VirtualDub with the NeatVideo plugin(not cheap) works very well too. You can then frameserve it over to TMPGEnc and skip a step. It(NeatVideo) is painfully slow though.
Your best bet would be to do "video only" too because of the "lag" factor.
MediaCoder x64 build 5175 video noise in DVD vob conversion
By ejai in forum Video ConversionReplies: 6Last Post: 21st Jul 2011, 21:12 -
Is there a program to clean mp3 file of torrent traces?
By aqualung2003 in forum AudioReplies: 3Last Post: 1st Jun 2011, 01:29 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
Clean up audio on AVI file
By marybutts in forum AudioReplies: 2Last Post: 11th Jan 2008, 07:15 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 19:31
