Have ripped a BR disc to the HDD using AnyDVD HD, then BD Info and finally TSmuxer.
TSmuxer Output options are: TS Muxing, M2TS Muxing, Create BR Disc.
My Questions...
(1) What is the difference between TS Muxing and M2TS Muxing, and which one should I use?
(2) Using TSMuxer, how do I compress the main file so as to fit onto a 25gb BR disc ??
(3) What happens when I select Create Blu-ray Disc ??
Thanks in advance
Zen
Closed Thread
PLEASE stop make new similar topics. Stay in ONE topic and it's MUCH easier to follow what you are doing. Just reply to add new information. Continue in https://forum.videohelp.com/topic359301.html
Homeplugs Advice needed
By iCaptainChaos in forum Newbie / General discussionsReplies: 3Last Post: 13th Apr 2012, 07:35 -
advice on specs needed for new pc
By angryassdrummer in forum ComputerReplies: 4Last Post: 21st Jun 2011, 01:31 -
Streamclip 1.9.1 - some advice needed please
By shoosh in forum MacReplies: 7Last Post: 13th Jun 2008, 18:09 -
Software advice needed
By ccm in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 12:01 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
