It have distubed me long time
im a eager snapshot taker when i use media player classic
thou as soon as i take the snapshot from a wmv-file at decired location
it plays back the video to previous key-frame (i suspect) when i hit the snap-button..within 5 sec it use to go back..and on the screenshot-output there Rachel Ryan will still have the bra on!![]()
no mpg and avi dont have this problem
is it possible to take a accurate wmv snapshot in this world is the question?
in my opinion we can exclude what codecs the computer have installed affects this
Frame accurate seeking is usually dependent on the splitter, decoder, renderer, and software player - so it might can a codec issue. Some allow proper navigation, some don't.
You can go forward frame-by-frame (not backwards) with MPC, but snapshots can only be taken using VMR9(renderless) or VMR7(renderless) and they may look faded. This is using WMV codecs installed with WMP11 (not ffdshow used to decode)
You can navigate properly fwd & backwards with vdub (you need wmv plugin, and if your source is wvc1, then you have to enable vc1 in the ffdshow vfw configuration). Screenshots are taken in full RGB and are more vibrant than using VMR9, for example. However vdub will not display anamorphic encodes or respect DAR flags. It will only display at full frame 1:1 pixel aspect ratio (which usually isn't a problem for most WMV) -
How wery interesting
as soon as i switched to use VMR7(renderless) the shots become accurate
and it accually generated screenshots even when being sett to "system deafult" but with the backslide-effect,
ok thanks for the tip
VLC - No Snapshots
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2012, 05:01 -
Frame accurate WMV edits
By jbeezer in forum EditingReplies: 5Last Post: 5th Jul 2010, 15:41 -
Requesting Demuxer advice
By grannyGeek in forum Authoring (DVD)Replies: 2Last Post: 12th Mar 2009, 03:23 -
convert wmv to mpeg for PS3 - Requesting expert advice again :)
By RS4 in forum Video ConversionReplies: 5Last Post: 14th Aug 2008, 20:00 -
How to take snapshots while playing a movie?
By download freak in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2007, 03:18
