Hi, I finished my WMM project, and saved it to dv-avi file (as I had always saved it to WMV file before but the video came out too blurry/grainy. The size is 7.35gb. Now I want to put it on a dvd to watch. But my dvd's are only 4.3gb. What should I do? I have convertxtodvd. Will that compress the file to fit the 4.3gb dvd? Will doing that cause degredation to the video quality?? Are there larger dvd's that hold more than 7.35gb?
James
You can use ConvertXtoDVD, or DVD Flick, or FAVC, or AVS2DVD. You have to convert the file to DVD compliant video and audio, as DV avi is not a valid DVD format. If you use a good quality encoder then the change will be minimal. 7.35GB DV is only about 35 - 40 minutes running time, so the quality should be high.
Read my blog here.
"If you use a good quality encoder" then the quality of the video will only slightly decrease. Is convertxtodvd a "good encoder"??? Or dvd flick??
James -
My preference would be FAVC, but only if you don't want fancy menus. or use FAVC, keep the working files, and author your disc in GUIForDVDAuthor.
Read my blog here.
Keepvid - how can you chose where the downloaded file is saved?
By jacknscoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 00:09 -
from ATI File Player to .mpg (or any format that fits WMM)
By croarta in forum Video ConversionReplies: 2Last Post: 22nd Dec 2010, 11:10 -
WMM Cannot Recognize .mpg File
By shecec in forum EditingReplies: 4Last Post: 9th Jun 2010, 10:07 -
Deleting VTS to reuse saved project
By ceedee39 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 20th May 2008, 17:08 -
WMM and DV-AVI
By jaydub in forum Newbie / General discussionsReplies: 3Last Post: 4th Dec 2007, 01:25
