Trying to use autogk, but getting an error from azid_P4.exe. Tried uninstalling and reinstalling, but getting the same error. I'd appreciate any ideas or suggestions.![]()
Sorry...here's more info
AutoGK 2.45
WinXP SP2
[11/8/2008 9:28:09 PM] AutoGK 2.45
[11/8/2008 9:28:09 PM] OS: WinXP (5.1.2600).2
[11/8/2008 9:28:09 PM] Job started.
[11/8/2008 9:28:09 PM] Input file: T:\VIDEO_TS\VTS_05_0.IFO
[11/8/2008 9:28:09 PM] Output file: T:\test.avi
[11/8/2008 9:28:09 PM] Output codec: XviD
[11/8/2008 9:28:09 PM] Audio 1: Unknown language AC3 2ch
[11/8/2008 9:28:09 PM] Subtitles: none
[11/8/2008 9:28:09 PM] Format: AVI
[11/8/2008 9:28:09 PM] Target size: 186Mb
[11/8/2008 9:28:09 PM] Custom resolution settings: fixed width of 640 pixels
[11/8/2008 9:28:09 PM] Audio 1 settings: VBR MP3 with average bitrate: 96Kbps
[11/8/2008 9:28:09 PM] Started encoding.
[11/8/2008 9:28:09 PM] Demuxing and indexing.
[11/8/2008 9:29:29 PM] Processing file: T:\VIDEO_TS\VTS_05_1.VOB
[11/8/2008 9:29:29 PM] Source resolution: 720x480
[11/8/2008 9:29:29 PM] Found NTSC source.
[11/8/2008 9:29:29 PM] Source aspect ratio: 4:3
[11/8/2008 9:29:29 PM] Analyzing source.
[11/8/2008 9:31:16 PM] Source has percentage of interlacing in motion areas: 36.45
[11/8/2008 9:31:16 PM] Source has percentage of telecined patterns: 0.83
[11/8/2008 9:31:16 PM] Source has percentage of progressive patterns: 60.95
[11/8/2008 9:31:16 PM] Source has percentage of interlaced patterns: 38.22
[11/8/2008 9:31:16 PM] Source is considered to be interlaced.
[11/8/2008 9:31:16 PM] Output will contain 53820 frames
[11/8/2008 9:31:16 PM] Decoding audio.
[11/8/2008 9:33:22 PM] Normalizing audio.
[11/8/2008 9:33:22 PM] Encoding audio.
EXCEPTION: Audio1 is corrupted. Encoding aborted.
[11/8/2008 9:33:22 PM] Job finished. Total time: 5 minutes 12 seconds -
Did you first rip it with DVDFab HD Decrypter?
Probably should upgrade to AutoGK v2.48b.
AutoGK Virtualdub error 2
By wulf109 in forum Video ConversionReplies: 1Last Post: 12th Aug 2009, 06:43 -
AutoGK error too many pictures per GPO
By debpie in forum DVD RippingReplies: 1Last Post: 24th Nov 2008, 15:07 -
AutoGK Error Message
By WuPhilly in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2008, 19:12 -
AutoGK error
By wulf109 in forum DVD RippingReplies: 2Last Post: 13th Apr 2008, 14:24 -
AutoGK / VDup Error - File in use (but its not)
By Fearnot in forum DVD RippingReplies: 7Last Post: 9th Dec 2007, 23:41
