http://www.fixya.com/support/t1221511-quantum_dlt8000_drivers_not_installing
Something strange going on with the installation of the drivers on my DLT8000. I'm able to use the xTalk program to run tests and stuff on the tape drive from windows so I know it's working properly. However, this is what the device manager says:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
and it shows the little red exclamation point. Getting to this spot was difficult because of some issue with the INF file which (I guess) I was able to fix via this blog post:
http://www.loosewireblog.com/2006/07/how_to_fix_a_br.html
I added the [ClassInstall32] to the very end of the INF file that came with the downloaded drivers from the Quantum website. I was able to determine that the key name for this type of device is:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{6D807884-7D21-11CF-801C-08002BE10318}
and sure enough, there is a subkey 0000 which contains all the info about my tape drive.
This is what my setupapi.log file is showing:
That #I163 error is probably what the problem is but I don't know what to do now... Any help is greatly appreciated.Code:#-199 Executing "C:\WINDOWS\system32\rundll32.exe" with command line: rundll32.exe newdev.dll,ClientSideInstall \\.\pipe\PNP_Device_Install_Pipe_0.{A270A48C-25F4-4B08-8975-00D9D0356FF2} #I060 Set selected driver. #-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0 #-018 Searching for compatible ID(s): scsi\sequential,scsi\raw #-166 Device install function: DIF_SELECTBESTCOMPATDRV. #W059 Selecting best compatible driver failed. Error 0xe0000228: There are no compatible drivers for this device. #W157 Default installer failed. Error 0xe0000228: There are no compatible drivers for this device. #I060 Set selected driver. #-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0 #-018 Searching for compatible ID(s): scsi\sequential,scsi\raw #-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0 #-018 Searching for compatible ID(s): scsi\sequential,scsi\raw #I022 Found "SCSI\SequentialQUANTUM_DLT8000_________" in c:\documents and settings\mike\desktop\dltdriver\QntmDlt.inf; Device: "Quantum DLT8000 Tape Drive"; Driver: "Quantum DLT8000 Tape Drive"; Provider: "Quantum Corporation"; Mfg: "Quantum"; Section name: "qntmdrv_Inst". #I087 Driver node not trusted, rank changed from 0x00000001 to 0x00008001. #I023 Actual install section: [qntmdrv_Inst.NTx86]. Rank: 0x00008001. Effective driver date: 10/19/2006. #-166 Device install function: DIF_SELECTBESTCOMPATDRV. #I063 Selected driver installs from section [qntmdrv_Inst] in "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf". #I320 Class GUID of device remains: {6D807884-7D21-11CF-801C-08002BE10318}. #I060 Set selected driver. #I058 Selected best compatible driver. #-124 Doing copy-only install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030". #E366 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn, user said ok). Error 0x800b0100: No signature was present in the subject. #W187 Install failed, attempting to restore original files. #E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject. #-024 Copying file "c:\documents and settings\mike\desktop\dltdriver\QDLTx32.sys" to "C:\WINDOWS\system32\DRIVERS\QDLTx32.sys". #E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\QDLTx32.sys" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject. #-166 Device install function: DIF_REGISTER_COINSTALLERS. #I056 Coinstallers registered. #-166 Device install function: DIF_INSTALLINTERFACES. #-011 Installing section [qntmdrv_Inst.NTx86.Interfaces] from "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf". #I054 Interfaces installed. #-166 Device install function: DIF_INSTALLDEVICE. #I123 Doing full install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030". #E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject. #I163 Device not started: Device has problem: 0x27: CM_PROB_DRIVER_FAILED_LOAD. #I121 Device install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030" finished successfully.
	The first error in that log is way up at the top:
 Are you sure you have the correct driver package?
 http://www.quantum.com/ServiceandSupport/SoftwareandDocumentationDownloads/DLT8000/index.aspxGoogle is your Friend
	Hmm...strange. With my DLT hooked to a SCSI card, I never thought about any drivers other than the SCSI controller. I never loaded specific dlt drivers on any of the PCs that had DLT drives. With the SCSI card, the DVD mastering software was always able to locate the DLT drive.
	You got errors out the Ying-Yang in that log file. Guess would be you got the wrong drivers, or they just don't work. Have you tried Quantum tech support, they make it and would be most likely to be able to provide correct answers.
 Did the drive come with the card, or was it purchased seperately? Double-check cables, SCSI id's, synch and speed settings?
	Another question, do you have a 3 party backup program installed aka Veritas?
  Quantum DLT8000 & SCSI card AvailableBy sdsumike619 in forum Authoring (Blu-ray)Replies: 1Last Post: 6th Dec 2011, 17:07
  So how the hell did they do this??!!By Chilla1142 in forum EditingReplies: 9Last Post: 1st Jun 2011, 10:46
  ffmpeg is hell...By nmaxwell in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2010, 04:47
  vp6 hellBy Mark69 in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 21:37
  [SOLVED] DLT8000 installed - 15 devices listed in device manager? ?By sdsumike619 in forum Authoring (DVD)Replies: 6Last Post: 19th Jun 2008, 20:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
