New Topic:
Somewhat useful reference for locating cable ClearQAM subchannels. (Also ATSC 8vsb for over the air)
SiliconDust makes a dual tuner box with clearQAM capability. As part of their support resources, users report QAM scans by zip code. When you enter your zip code, they report user QAM scans as a composite list using virtual names for clearQAM against actual cable channels. If no data exists for your zip, they report a composite for all responses for the first three digits of your zip code and so on.
These scans are useful at least as a guide. You can manually enter indicated subchannels that don't show after your local scan. You might find something new. Put your zip code into this link.
http://www.silicondust.com/hdhomerun/channels
http://www.kiva.org/about -
I have the SiliconDust LAN tuner. Works very well. Unfortunately, my available cable has no HD broadcasting available. It's a private system, similar to a hotel/motel satellite feed.
But the tuner does pick up about 25 local OTA HD channels.
Nice resource link, though.
Hauppauge Wintv-HVR-1600 ClearQAM VLC capture
By rhijaen in forum Capturing and VCRReplies: 0Last Post: 25th Oct 2009, 20:53 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
COMCAST clearQAM
By mars396 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Nov 2008, 13:06 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 14:50 -
Help locating a possible identity theft
By chewie8008 in forum ComputerReplies: 16Last Post: 10th Mar 2008, 09:17
