My uncles laptop when playing dvds does not have audio. But the audio works in other thing such as the internet any suggestions as to why it might not work? Its vista.
We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950)
I tried playing an audio cd and that works but not dvds or movies
We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950) -
Have you checked the 'Volume Mixer'? It may not have the audio set up for DVDs. Does it play a audio CD with the same drive? Vista has settings for each device, including the DVD/CD player.
If you go to the 'Control Panel>Sound' you should find the settings. (Classic View) Or if you have the icon on your Taskbar; R click on that.
What program are you using for playback? If you have Vista Premium or higher, it has the included DVD player. Otherwise, try VLC media player if Windows Media Player is being uncooperative.
If VLC works, then you may have a codec problem.
EDIT: CDs use WAV audio. DVDs most often use Dolby AC3 audio. It may be you are missing the AC3 audio codec. Try installing AC3 Filter.
problem with a videoclip doe Tablet Samsung
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2010, 01:54 -
Lap Top & Internet Question
By DuBsTaR in forum ComputerReplies: 5Last Post: 10th Mar 2008, 19:34 -
Lap top to pc
By LabanB in forum ComputerReplies: 8Last Post: 3rd Feb 2008, 09:57 -
dvd +r made on lighton 5001 can't be read on desktop or lap top
By skydiverbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 27th Jan 2008, 15:02 -
Can't play dvd on my lap top!
By BSarte in forum Software PlayingReplies: 2Last Post: 16th Sep 2007, 08:43
