Greetings:
Using my HP HDX9494NR desktop replacement, I am able to watch the BluRay Hulk movie on my HDTV (TH-50PX77U) using the latest Quickplay 3.7 (I think it's an HP custom PowerDVD) and the sound comes out thru my 7.1 receiver (Denon AVR-4806) and 7.1 speakers system via the HDMI laptop port. However, the sound is decoded in stereo instead of 5.1 DTS even though the movie menu setting shows 5.1 DTS as default.
If I go to the advanced tab in QP, the options are only 2 channel 44.1, 48, 88, KHz etc. I try different frequencies but the optimal sounds is the 44.1KHz. I wonder if this is normal.
I also update to the latest audio driver dated 08/2008 (the old one is dated 07/2007) to no avail.
The sound is decoded correctly as DD, DTS etc if I use DVDs instead of BluRay. In other word, for some reason QP does not decode the sound properly only in BluRay. As for WinDVD 9 and AnyDVD 6.4.7.9 is not a viable solution since the movie is jerky. The sound is decoded correctly as 5.1 DTS but the movie is unwatchable since the movie frames froze and unfroze frequently.
Any idea what I might be missing?
Thanks in advance for your time and help.
Results 1 to 1 of 1
What's the latest on VHS capture?
By loninappleton in forum Capturing and VCRReplies: 16Last Post: 17th Oct 2010, 23:00 -
Blocking artifacts in H.264 decoded video
By gabbasb in forum ProgrammingReplies: 0Last Post: 18th May 2010, 05:44 -
Latest Version of VLC
By Wanderlustus in forum Software PlayingReplies: 6Last Post: 20th Feb 2009, 13:47 -
VideoLAN, Windows Vista Ultimate and QuickPlay
By jackowens in forum Software PlayingReplies: 2Last Post: 3rd Jul 2008, 18:02 -
THE latest greatest word
By RabidDog in forum Off topicReplies: 2Last Post: 20th Jul 2007, 01:22
