Help please if you can....I was using my dvd flick to convert my avi to dvd. I set it to burn and create an iso, so that i could make another copy afterwards. When I went to re-burn it from the iso, I found that dvd flick had made the iso into a winrar file (if unzipped, it gives me not a complete iso,but video and audio folders). I know that I can use the audio and video files to re-burn the project, but am wondering what has happend, and what do i do to change it back? I've used dvd flick for about 2 years now and this is the first time ive seen this. I haven't changed any settings on the computer that I know of, can someone please help? P.S. this is also my first computer EVER (about two years now) and am learning as I go.....so be gentle with me!!!
All that's happened is the program association (the program Windows uses when you double click on an icon) for ISO file has been set to WinRAR. Your files are still ISO images. Just open them with your regular ISO app. It may have a setting to grab the file association back. Or you can right click on an ISO file and select Open With -> Choose Program, then enable the "Always use selected program..." option to reset the association.
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
DVD Flick & ISO size issue
By jnojr in forum Authoring (DVD)Replies: 8Last Post: 6th Jan 2010, 19:57 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03 -
Question about using winrar to detect corrupt iso file
By jimdagys in forum ComputerReplies: 1Last Post: 13th Oct 2008, 20:07 -
Loses colour when DVD recorder turned off
By rharris in forum DVD & Blu-ray RecordersReplies: 5Last Post: 27th May 2007, 18:45
