Results 1 to 11 of 11
  1. I recently borrowed a Hitachi (mini DVD) camcorder from a visiting friend. I was 100% certain that I successfully recorded on the DVDs because I was able to watch (repeatedly) all the footages when I played it on the camcorder. I have since then returned the Hitachi camcorder and my friend already left for overseas.
    The problem is when I tried to watch the DVDs on my PC recently, the disk drive can't read (or see) anything except a 44kb audio file. It can't see any available video files. I tried using a different PC and it still can't be read.
    I have extensively googled about it and even scoured the Hitachi website for support and didn't find the solution that I was looking for.
    Would there be any downloadable application or software that would allow me to read these DVD-Rs?
    Apr 2004
    Miskatonic U
    My guess is that you did not finalise the discs in the camera before your friend left. Unfinalised discs will often not play correctly in anything but the recording camera (or another of the same make and similar model). if you can get hold of a similar camera you may be able to finalise the discs in it. Otherwise you could try ISOBuster (not free), which some have been able to use in similar situations to recover footage.
    Worst case, post the discs to your friend, get him/her to finalise the discs, and post them back to you.
    Read my blog here.
  3. Wow. Thanks for the quick reply guns1inger. I'll go and check out ISOBuster.
    Dec 2008
    We used our daughter's hitachi dzmv200a mini dvd camcorder to record Christmas. My daughter finalized the disc and we brought it home to our house. We can watch the disc but cannot copy it to the hard drive in our computer or the hard drive in our dvr. Any ideas on how to copy the disc?
    Jan 2009
    afghanistan
    well, i am having the same problem, i have got a dvd which can be played in stand alone dvd set but can be played in my pc, when i insert the disk i shows the disk blank and no file is shown inside.
    could you please help me to be able to play the dvd in my pc?
    thanks
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Make sure is has been finalised correctly in the device that created it (recorder). Consult your manual for instructions.
    Read my blog here.
    Jan 2009
    afghanistan
    well, i am having the same problem, i have got a dvd which can be played in stand alone dvd set but can not be played in my pc, when i insert the disk i shows that the disk is blank and no file is shown inside.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    sanaie: Tried Isobuster? And try on another computer.
    Jan 2009
    afghanistan
    hi,
    i used isobuster, it was really great i appreciate for proper suggestion. i managed to recover most the .vob files from dvd disk but some file had errors which were not extractable. any idea how to deal with this?
    thanks
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Perhaps ISOPuzzle ? Also worth trying to read it in a different reader. If all that fails, you may have to write the rest off as lost.
    Read my blog here.
    Dec 2008
    Thanks for all the help. I was able to copy one disc but the other one will not go, perhaps it just has too many errors.
