    Nov 2008
    Hi all,
    I have a bunch of .ts files that I would like to convert to MP4s. I figured I'd use mkv2vob, but that gives an error "Unsupported audio codec: MP3". I have also tried both AVI-Mux GUI and VirtualDub, neither of which allow me to open the .ts files.
    Is there a way to do this in mkv2vob, or can anyone suggest a program that will allow me to do this?
    What is the video and audio codec in your ts? Identify using mediainfo.
    Do you want to play it on a ps3/xbox 360/console?
  3. What kind of .ts files? (what video & audio codecs)
    Use mediainfo (view=>text)
    EDIT: Baldrick too fast 4 me
    Nov 2008
    Wow, you guys are fast. Here's the output from mediainfo:
    General
    Complete name                    : Caves.ts
    Format                           : MPEG-TS
    File size                        : 2.12 GiB
    Duration                         : 53mn 0s
    Overall bit rate                 : 5 714 Kbps
    Video
    Menu ID                          : 1 (0x1)
    Format                           : MPEG Video
    Format version                   : Version 2
    Format profile                   : Main@Main
    Format settings, Matrix          : Default
    Duration                         : 53mn 0s
    Bit rate mode                    : Variable
    Bit rate                         : 5 263 Kbps
    Width                            : 1 280 pixels
    Height                           : 720 pixels
    Display aspect ratio             : 16/9
    Frame rate                       : 23.976 fps
    Colorimetry                      : 4:2:0
    Scan type                        : Progressive
    Audio
    Menu ID                          : 1 (0x1)
    Format                           : MPEG Audio
    Format version                   : Version 1
    Format profile                   : Layer 2
    Bit rate mode                    : Constant
    Bit rate                         : 224 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 48.0 KHz
    Resolution                       : 16 bits
    My goal here is indeed to play this on my PS3.
  5. You have MPEG2 video and MP2 audio
    You can convert to h264 video and AAC audio in .mp4.
    Options include avidemux, ripbot264, xvid4psp
    xvid4psp and ripbot264 are probably the easiest to use, both have PS3 preset profiles
    You may have to install haali media splitter, and ffdshow if you don't already have those
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Try mux it to a mpeg-ps stream using tsmuxer and I think it will work without any conversion. See http://www.avsforum.com/avs-vb/showthread.php?s=a0b148c6488adc9a0bcbce7d4ee5bf77&p=149...9#post14989129
    Nov 2008
    Thanks guys. XviD4PSP has done the trick for me.
