At work we have this outdated but useful program at runs in a DOS window. The problem is that the only option to print a report is via LPT port. I thought i read somewhere that i could do a virtual port LPT and make it print thru the USB printer. anyone know how?
I am not sure if this will help:
http://support.microsoft.com/?kbid=154498
If you don't have a server you can share your printer on your workstation and then run this:
net use lpt1: \\<your machine name goes here>\hp6300
I followed this with:
copy con lpt1:
Testing print
^Z
1 file(s) copied.
and a document appeared in my WIndows XP printer queue. I am not sure if the application actually polls the LPT port - I have seen applications where a physical printer must be connected to the LPT port for the program to begin to print - even to print to a network printer captured as above. If that is the case running a DOS emulator or VMWare should work. I have successfully used LPT based scanners in Windows XP with a VMWare Windows 98 host. The Windows HAL may be a problem with direct access to the port.
Good luck. -
I don't know if this is an option, but you may be able to simply write a new program if it is a simple printing matter.
We had a ton of DOS programs at my old job that i was able to integrate into a Word macro. Things like databases and report generators.
Also, there are often free Windows versions of the software that you would like to replace.
LG DV382 - USB Port
By Yabuike in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Oct 2011, 08:41 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
USB port on DVP
By hootal in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2008, 09:35 -
USB 2.0 Port and RAM?
By LCE in forum ComputerReplies: 11Last Post: 6th Nov 2007, 01:01 -
USB Port Connection
By BillP2 in forum ComputerReplies: 19Last Post: 27th Sep 2007, 02:49
