Hi,
Can anyone tell me how to view the attached file? I've tried it on two computers and with a few programs, and none of them work. If anyone is able to figure out what I need to do to view it, I would greatly appreciate it!
CB55
test.wmv
I captured it with a USB wireless camera, model 812GA2, manufactured by AGPtek. Capture device is TridVid. I used Windows Movie Maker to record, and in the preview window while recording, it looks normal, but when played back, the attached file is what I get out.
The camera spec says it records in 510x492 (NTSC), but the file says it's 720x480. I don't really know anything about this stuff, but I desperately need to get this file fixed...
Is there a company that anyone could recommend that might be able to unscramble this file?
You probably won't be able to "unscramble" it because it is recorded that way into the .wmv file
You probably have to capture it correctly in the first place (i.e. I don't think this is a software playing issue, or a decoding issue)
How to view Windows Photostory WMV files on MacOS
By peerv in forum User guidesReplies: 0Last Post: 25th Jul 2011, 09:55 -
Lately, I can't view some wmv files
By videocheez in forum Software PlayingReplies: 6Last Post: 23rd Nov 2008, 18:54 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 01:01 -
How to view wmv.cfm files
By noles7 in forum Newbie / General discussionsReplies: 3Last Post: 7th Dec 2007, 12:21 -
Distorted sound
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 17th Oct 2007, 19:40
