Hi
It's been a while since I've been on here. After many years I've had to reinstall Windows XP Pro (SP3). So now I'm reinstalling DVD Maestro v9. I've also reinstalled CineMaster 2000 for the preview function, but it's not working. Both installs say they worked successfully.
DVD Maestro is not detecting Cinemaster's codecs and so is coming up with the old message "Realtime preview funtionality will not be available because no decoders have been detected.(0x410a0011)"
Googling this has not helped. Everything I find says "install Cinemaster 2000", which I have, but does not go into resolve problems when the Cinemaster install has failed to enable the RealTime preview.
Any help at all would be most gratefully received.
Many thanks in advance.
Ian.
				Results 1 to 11 of 11
	I put the files that the Cinemaster install program installs in the SYSTEM32 folder into the directory that has DVDMaestro. I find that this works for me.
 IIRC, there are three or four .DLL files that need to be moved.
 Were you previously able to get a realtime preview using XP SP3?ICBM target coordinates:
 26° 14' 10.16"N -- 80° 16' 0.91"W
	I moved the following Cinemaster files to the DVDMaestro Directory:
 CINEMAST.DLL
 CINMHOOK.DLL
 CINMST32.DLLICBM target coordinates:
	I only used this last on XP SP2, but it was an old install. First time I'm doing it on SP3. I'll find the DLLs and move them and let you know how I get on.
	Hi, I got the same problem. After a fresh install of XP SP3, I am unable to preview my work in dvdmaestro. The only slight workaround I have found is to load powerdvd before hand to get at least an audio-only preview. Anyone have a solution?
	I have XP with SP3 and preview works for me with the following files - repeated but I'm lazy to test what is not needed  : :
 [System]
 cin32thk.dll
 Cinemast.dll
 cinemres.dll
 CinemSup.sys
 Cinmhook.dll
 Cinmst32.dll
 Dvdpld32.dll
 Mcicinem.drv
 qiswcine.cpl
 RPC2.dll
 Swcmcfg.dll
 [System32]
 cin32thk.dll
 Cinemast.dll
 cinemres.dll
 CinemSup.sys
 Cinmhook.dll
 Cinmst32.dll
 Dvdpld32.dll
 Mcicinem.drv
 qiswcine.cpl
 RPC2.dll
 Swcmcfg.dll
 [Drivers] under [System32]
 cinemsup.sys
	Thanks for your reply. I have all the files in the respective directories as well as the dvdmaestro folder for good measure. I still get the error message.
 REAL TIME PREVIEW FUNCTIONALITY WILL NOT BE AVAILABLE BECAUSE NO DECODERS HAVE BEEN DETECTED (0X410a0011)
 Is there some kind of registry entry I am missing or something?
 This is just weird.
 Thanks in advance.
	is this a simple codecs problem ? Download AceMegaCodec Pack and install it has codecs to cover virtually everything both audio and video wise ! For me this is one of the first things i install onto my system after formatting and the updated pack has just been released. !
	no, it's not. Maestro doesn't work with new codecs but dedicated Cinemaster.Originally Posted by proripp
 Perhaps, I don't know.Originally Posted by garyk
	I installed DVDMaestro onto an XP SP3 system and everything is functioning normally. I don't normally install anything into the Windows system directories, for reasons stated here (the directory of the launched program is the first that Windows will search).
 I did find that I have four of the .DLL files in the program directory. The fourth file is DVDPLD32.DLL.
 As for installing any megaCODEC pack, that is the LAST thing that I would do. You'll spend the next couple of months just trying to restore everything back to normal.ICBM target coordinates:
	Thanks for your reply. I have the k-lite codec pack installed. These are the mpeg related items installed:
 --directshow filters klite--
 mpeg ts splitter (haali)
 mpeg splitter (gabest)
 --directshow filters miscrosoft--
 mpeg splitter
 mpeg2 sections and tables
 --directshow filters other--
 mpeg2 decoder (gabest)
 mpeg 1-2 decoder (mainconcept)
 I am a little worried because I'm not sure what the effect of uninstalling these would have.
  Best tool for realtime DV preview/capture?By Drevin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Feb 2011, 10:28
  Preview not workingBy dweinin in forum ffmpegX general discussionReplies: 3Last Post: 19th Jan 2011, 13:39
  VOB2MPG Pro preview not working & conversion slowBy MDJH in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 22nd Sep 2009, 15:01
  Title Preview not workingBy Neil Goodwill in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 5th Mar 2008, 09:00
  ffmpegx autocrop and preview not working anymoreBy skankmonky18 in forum ffmpegX general discussionReplies: 6Last Post: 22nd Aug 2007, 02:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
