Hi..I hope someone can help me..I've been using DVD Flick for a short time now and have been successful in using the program up until now. I was trying to convert an AVI file of a 45 min TV show when I recieved this error message.
DVD Flick error log
Version 1.3.0.4 build 726
Windows 5.1 build 2600 Service Pack 3
*** Project info
EncodeProf 2
Threads 1
OverScan 0, 3
TargetRate 0
TargetFormat 1
TargetSize 4
CreateISO 0
CustRate 0
EnableBurn 0
EraseRW 1
HalfRes 0
LoopPlayb 1
AutoPlayMenu 1
MenuEnable 0
MenuTemplt Mosaic
VolumeMod 100
WhenPlayed 0
*** Warnings given
*** Titles
0 - Gossip Girl S02 E06
ChaptCount 10
ChaptInt -1
ChaptSource 1
TargetAR 1
ThumbIndex 251
*** Project sources
C:\Documents and Settings\Owner\Desktop\MY J0iNTS\Gossip.Girl.S02E06.HDTV.XviD-DOT.[VTV].avi
Stream 0 (2)
Dur 2513.92
StartT 0
Compr mpeg4
BitR 0
624x352 23.976 FPS
PAR 1
SAR 1.772727
Stream 1 (1)
Dur 2513.92
StartT 0
Compr mp3
BitR 112
Chnnls 2
SRate 48000
Delay 2
*** dvdflick.log
3:34:07 PM: DVD Flick 1.3.0.4 build 726
3:34:07 PM: Calculating stream sizes...
3:34:07 PM: Disc space used : 2513920 KB
3:34:07 PM: Average bitrate : 8000 Kbit/s
3:34:07 PM: Total duration : 41:53 minutes
3:34:07 PM: 1 title(s).
3:34:07 PM: Using Normal encoding profile.
3:34:07 PM: NTSC target format.
3:34:07 PM: CPU: Intel(R) Pentium(R) 4 CPU 2.20GHz
3:34:07 PM: Threadcount: 1
3:34:07 PM: Encoding video...
3:34:07 PM: Title 0, source 0
3:34:07 PM: Source : C:\Documents and Settings\Owner\Desktop\MY J0iNTS\Gossip.Girl.S02E06.HDTV.XviD-DOT.[VTV].avi
3:34:07 PM: Properties : 624x352, 1.77:1, 23.976 FPS, mpeg4, 2513.92 seconds
3:34:07 PM: Target BitRate : 8000 Kbit\s
3:34:07 PM: Re-encoding
3:34:07 PM: -i "C:\Documents and Settings\Owner\Desktop\MY J0iNTS\Gossip.Girl.S02E06.HDTV.XviD-DOT.[VTV].avi" -vcodec mpeg2video -s 712x480 -padleft 4 -padright 4 -r 23.976 -g 14 -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -aspect 16:9 -minrate 7950k -maxrate 7950k -b 7950k -preme 1 -precmp 2 -subcmp 8 -mbcmp 8 -cmp 1 -sws_flags lanczos+accurate_rnd -mbd 2 -sc_threshold -3000 -dc 8 -an -threads 1 -fflags +genpts -strict very -f mpeg2video -shortest -map 0:0 "C:\Documents and Settings\Owner\My Documents\dvd\0.0.m2v"
4:15:25 PM: Applying 2:3 pulldown
4:15:25 PM: "C:\Documents and Settings\Owner\My Documents\dvd\0.0.m2v" "C:\Documents and Settings\Owner\My Documents\dvd\pulldown.m2v"
4:23:23 PM: Combining video sources...
4:23:23 PM: Concatenating video...
4:23:23 PM: Encoding audio...
4:23:23 PM: Title 0, track 0, source 0 of 0
4:23:23 PM: Source : C:\Documents and Settings\Owner\Desktop\MY J0iNTS\Gossip.Girl.S02E06.HDTV.XviD-DOT.[VTV].avi
4:23:23 PM: Properties : 2 channels, 48000 Hz, mp3, 2513.92 seconds
4:23:23 PM: Recompressing to 192 Kbit\s with 2 channel(s)
4:23:23 PM: -i "C:\Documents and Settings\Owner\Desktop\MY J0iNTS\Gossip.Girl.S02E06.HDTV.XviD-DOT.[VTV].avi" -i "C:\Documents and Settings\Owner\My Documents\dvd\0.0.m2v" -map 0:1:1:0 -acodec ac3 -ab 192k -ac 2 -ar 48000 -threads 1 -async 0 -shortest "C:\Documents and Settings\Owner\My Documents\dvd\0.0.0.ac3"
4:27:14 PM: Fixing delay of 2 ms
4:27:14 PM: -start 2 "C:\Documents and Settings\Owner\My Documents\dvd\0.0.0.ac3"
4:27:32 PM: Combining audio sources...
4:27:32 PM: Concatenating audio...
4:27:32 PM: Title 0, track 0
4:27:32 PM: Combining sources...
4:27:32 PM: Multiplexing audio and video
4:27:32 PM: Title 0
4:27:32 PM: -m d -N -P -o "C:\Documents and Settings\Owner\My Documents\dvd\title0.mpg" -i "C:\Documents and Settings\Owner\My Documents\dvd\0.0.m2v" -0 "C:\Documents and Settings\Owner\My Documents\dvd\0.0.ac3"
*** 0.0.0_log.txt
[Input info]
Bitrate=192
Actual rate=192.000000
Sampling Frec=48000
TotalFrames=78551
Bytesperframe= 768.0000
Filesize=60327168
FrameDuration= 32.0000
Framespersecond= 31.2500
Duration=00:41:53.632
Channels mode=2/0: L+R
LFE=LFE: Not present
[Target info]
StartFrame=0
EndFrame=78550
NotFixedDelay= 2.0000
====== PROCESSING LOG ======================
Number of written frames = 78551
Number of Errors= 0
*** ffmpeg_audio_title0_track0_source0.txt
80]Invalid and inefficient vfw-avi packed B frames detected
size= 58780kB time=2507.97 bitrate= 192.0kbits/s
[NULL @ 0x3ec780]Invalid and inefficient vfw-avi packed B frames detected
size= 58910kB time=2513.47 bitrate= 192.0kbits/s
size= 58913kB time=2513.63 bitrate= 192.0kbits/s
video:0kB audio:58913kB global headers:0kB muxing overhead 0.000000%
*** ffmpeg_video_title0_source0.txt
2.0 size= 2438554kB time=2512.80 bitrate=7949.9kbits/s
[mpeg4 @ 0x3ec9e0]Invalid and inefficient vfw-avi packed B frames detected
frame=60262 fps= 24 q=2.0 size= 2439121kB time=2513.39 bitrate=7949.9kbits/s
frame=60273 fps= 24 q=2.0 Lsize= 2439566kB time=2513.84 bitrate=7949.9kbits/s
video:2439566kB audio:0kB global headers:0kB muxing overhead 0.000000%
*** pulldown_title0.txt
= 60139
Current GOP = 4315 Current Frame = 60153
Current GOP = 4316 Current Frame = 60167
Current GOP = 4317 Current Frame = 60181
Current GOP = 4318 Current Frame = 60195
Current GOP = 4319 Current Frame = 60209
Current GOP = 4320 Current Frame = 60223
Current GOP = 4321 Current Frame = 60237
Current GOP = 4322 Current Frame = 60251
Current GOP = 4323 Current Frame = 60256
Current GOP = 4324 Current Frame = 60270
*** tcmplex_title0.txt
stream: byte offset 59724293 of 60327168. 99%
INFO: Found 78551 audio frame headers, stream bit offset 482617344.
INFO: AC3 audio stream information
INFO: Stream length : 60327168
INFO: Syncwords : 78551
INFO: Frames : 78551 size 768 bytes
INFO: Bit rate : 24576 bytes/sec (192 kbit/sec)
INFO: Frequency : 48.0 kHz
ERROR: Unable to open program file C:\Documents and Settings\Owner\My Documents\dvd\title0.mpg.
*** Project destination folder
0.0.0_log.txt 447
0.0.ac3 60327168
0.0.m2v 2498101248
dvdflick.log 3084
errorlog.txt 0
ffmpeg_audio_title0_track0_source0.txt 89579
ffmpeg_video_title0_source0.txt 517659
pulldown_title0.txt 188821
tcmplex_title0.txt 8480
title0.mpg 4482760704
*** Drives
A - not ready
C - - 2
FS NTFS
AvailSpace 9694
FreeSpace 9694
TotalSize 39198
D - not ready
E - not ready
F - My Book - 2
FS FAT32
AvailSpace 278133
FreeSpace 278133
TotalSize 305168
G - not ready
H - not ready
This error message seems to come up at the Combine sources stageI think.
I am using Windows Xp Home edition.
Thank you in advance.
Results 1 to 1 of 1
DVD FLICK -always same error
By phonkilla in forum Authoring (DVD)Replies: 8Last Post: 16th Jun 2013, 09:24 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
avi to dvd error
By psy93 in forum Video ConversionReplies: 10Last Post: 6th Jul 2010, 11:32 -
DVD Flick gives me an error
By shashgo in forum Authoring (DVD)Replies: 11Last Post: 29th Jan 2009, 08:11 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20
