Hello To All i'm a new user (from italy sorry for my english) ad i have a huge problem whit my Samsung DVD-HR734 When I Try To Record A TV Program It Stops And i see these message You Canot Record Protected Movie
i read i other topic the problem is macrovision filter how can i disable it????
it is urgent pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeasssssssssseee eeeeeeeee
thancks
I changed the subject. Please do NOT use just urgent problem!!!!!!!!!!!!!!!!!.
Are you recording from the built in tuner or from a STB using line inputs?
If from line inputs you could put a macrovision filter between the STB and your DVDR. If you're recording from the built in tuner your choices are more limited since you can't put the filter between the built in tuner and recorder.
In the US filters are easy to find on the internet, I'm not sure about in Italy though. -
Very few recorders have software hacks to disable copy protection, and generally it's just for Macrovision while I believe that in television they use a different protection called CGMS. Putting a device called the Grex (which removes all copy protections) between the cable or satellite box and the recorder should fix the problem. The website for the Grex is: http://www.xdimax.com/grex/grex.html
Need help with Samsung dvd recorder
By Espo99 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Jan 2012, 05:47 -
I can't get my Wharfdale DVD recorder to record in 16:9
By AndyLGR in forum Newbie / General discussionsReplies: 7Last Post: 12th Jul 2011, 08:27 -
Record problem Samsung DVD-HR773
By alexfels in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Mar 2010, 06:45 -
any way to record from TV to DVD recorder?
By thedriver2200 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 10th Jun 2008, 12:37 -
Samsung DVD recorder
By aye in forum DVD & Blu-ray RecordersReplies: 2Last Post: 22nd May 2007, 07:01
