Take a short (representative) clip, say 2 minutes, and convert that 5 times, using the different decoders and encoders. The speed differences will be about the same for other movies.
The log nicely notes a start and end timestamp, so the duration of the processes is easily retrievable.
I haven't compared them systematically yet, but QuickTime decoding sure slows things down.
I began with a test clip called pook.avi: 62 891 452 Bytes, 6:04 minutes duration.
I used default settings, but authoring turned off.
For the first 3 trials, I used MPEG2ENC to do the encoding:
1. Using FFMPEG to decode: 6:42 minutes
2. Using Quicktime to decode: 5:05 minutes
3. Using MPLAYER to decode: 8:59 minutes
For the next 3 trials, I used FFMPEG to do the encoding:
1. Using FFMPEG to decode: 3:38 minutes
2. Using Quicktime to decode: 5:49 minutes
(MPLAYER wasn't an option)
Well these results are a bit strange. So using FFMPEG to decode is the fastest, but only when using it to encode as well. MPLAYER is the slowest decoder. Quicktime was a lot quick than I had anticipated. Of course this will also depend on the codecs installed on your computer.
Source file details:
Need new non-AC3Filter AC3 decoder from Expression Encoder
By CasanovaFly in forum AudioReplies: 17Last Post: 30th Jun 2011, 17:41 -
How much MCPS a Video Decoder on target can consume if the clock speed at w
By goldenmean in forum Newbie / General discussionsReplies: 0Last Post: 2nd Mar 2010, 08:12 -
Reccomend a good 5.1 decoder/encoder software
By 1980sumthin in forum AudioReplies: 2Last Post: 25th Jun 2009, 19:47 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 19:44 -
mplayer/encoder speed up video
By crazychicken in forum LinuxReplies: 0Last Post: 20th Apr 2008, 20:54
